Did not see this listed. Apologies if I missed it.
Southern California HOV lanes. Its a double yellow which changes to dashed white when you are allowed to enter and exit the lane. My car wanted to exit most of the times the white dashes were transitioning back to the double yellow.
The electronic stability control may have helped. The logs would record this.Had a bad scare this morning. If you saw a Model S do an impromptu sliding maneuver, in the rain, at 60mph, this morning on the I90 east bound near Seattle, that was me...
Not the fault of autopilot. A brand new (paper sticker) Mercedes 300 swerved into my lane and would have caused an accident if I had not been paying attention. Again, no fault of autopilot as the driver weaves sharply into my lane without indication or blind spot check. By the time the collision alert chimed I was already swerving into the hov lane to avoid. You know things are going to be fun when time slows and you purposely have to try to not react harshly - no time to curse or gesticulate - one of those moments...
Anywho, what does this have to do with autopilot? Well, autopilot was on - my hands actually resting on the wheel - when I had to swerve. I ended up over-correcting as the extra 1/10th of a second to overcome the "reluctance" of the wheel to cede control caused me to turn harder than I would normally have done. Then, when the lane steering disabled, the steering wheel became a lot more compliant and I was turning a lot more than I anticipated. I did slide a little and managed to get the car under control quickly, though I thank goodness that I used to rally drive many years ago. I had broke traction and at that speed in heavy traffic I was extremely grateful that I remembered some of my rainy Tarmac stages and didn't spin out.
Think it's worthwhile contacting TM and see if they want to pull and analyze the logs?
Btw I resisted the temptation to road rage the Mercedes; rather I continued behind them (on Autopilot) and watched them do the same thing to a motorbike. This took the proverbial biscuit, so I continued to follow them off the freeway, take some photos of the car and paper sticker, then passed this on to the authorities with the intimation they were likely drunk.
MikeBur, that is crazy! Thank goodness for your attentiveness, quick action, and WRC skills!
I've had the same thought cross my mind when the car unexpectedly veers onto an exit ramp. As an attentive driver, you rapidly observe what is happening and you immediately take corrective measures. But your hand is met with a surprisingly reluctant wheel and a degree of force that is far in excess of any steering input that the Tesla has ever requires. This certainly delays the proper corrective steering input by a half second, and then throws off the rest of your corrective inputs when the stiff steering goes suddenly compliant. Perhaps the "I'm taking the wheel" programming needs to soften the effort necessary to take control. It's a bit of a wrestling match right now!
You know, I think it might be a good idea if Tesla were to team up with a dash cam manufacturer and make a unit that could do a streaming upload to Highway Patrol or local police. Instead of road rage, just send in the evidence of reckless driving and let the authorities deal with them. With Geo location capabilities, the police should know exactly where the bad guys are at.
I set my steering to sports, so quite used to the "more effort" type of steering. Hence the transition from AP to driver is not that bad for me. If Tesla were to set the torque sensing lower, it may discourage people to comply with the hands on wheel approach, due to too early AP to driver switch.
lg_golfs said:...
Most likely the AP software is thinking that the approaching double yellow lines are
the division between your direction of traffic and oncoming traffic, and it wants to
get you back to the right of those "center" lines to avoid possible oncoming traffic.
So, apparently driving in HOV lanes is not yet a supported lane-marking type.
Update on TRACTOR-TRAILERS: had many opportunities to test this out this week and it seems to be a shadow phenomenon. Only consistent time this happened is driving south in the afternoon, passing in the left lane in the large truck's shadow. I think AP may sense it as an obstruction (although the proximity sensors (white/yellow, etc) don't go off) and suddenly will veer car to the left. No "hold wheel" warning, either. I have used AP passing no-shadow trucks without issue. Will keep testing......
Wet pavement at night with glare from street lights/other vehicle headlights.....NOT all the time but can happen suddenly.
I'm on a highway trip at present and will look for similar behaviors. When you say, "veers left" does the autosteer shut off, does the car stay in its lane but change to the other side of the lane? Please give a bit more info. Thx.
What has happened to me is that the camera/car 'hunts' for the other lane line which it lost because of the shadow and tries to 'jump' behind/into the truck's lane.
What interests me most at this time is whether the blue line for that lane on the autopilot dashboard image disappears at such times. We ought to keep an eye out for that situation. I have videos from a webcam and from a video cam aimed at autopilot image from today's drive and will try to see if blue lane disappears next to truck casting a shadow.
I will beef up a statement about big trucks on the first post because of these continued reports.
Papa: It is certainly not all the time. The shadow and your car's position has to be 'just right'. I have tried to duplicate it unsuccessfully, at times.
This is precisely why I won't really be using auto-steer anywhere around busy areas when driving at speed. Even if everything is working perfectly it's going to change the dynamics of the reaction. In your case it turned out okay because of your mad skillz. But, most of people won't have that. We're in this weird stage of giving up control to the computer, but we still have to maintain control. So that means there is this momentary transition time.
This kind of situation isn't all that rare either especially given how many people are texting while driving, or who are impaired (drunk, high, etc). We desperately need self-driving cars, but the transition to them is a rough one.
So aside from training/testing the autosteer (when I'm more attentive than normal) I'll stick to using it either in traffic jams or in the middle of nowhere when I can relax.
Mad skillz? ;-)
in in all seriousness, after driving another 250 miles today I prefer auto-steering for empty freeways rather than congested ones. I was really impressed at the ability of auto steering to cope well with pretty heavy fog at 5-6am on SB I5 today. There were areas where the system was disabled, though this was only for a few miles. Off freeway (single carriage way) roads were pretty good, requiring manual intervention only a few times.
One thing I have noticed is that the system is a LOT better ignoring exit ramps now, though the number of "hold the wheel" warnings have increases - I strongly suspect that these warnings are where others have overrode the system, eg approaching a number of bridges I had this happen, and I can imagine at certain times of day there is a hard shadow.
i am still thoroughly impressed by this system overall!
Figure 1. On the display you can see the grey semicircle showing that the Tesla is aware of the obstacle to the left of the car. The Tesla then moved more towards the middle of the lane. Notice that I have white dashed lane markers to the right and a solid yellow line marker to the left.
Now I cross the state line and pavement turns to concrete. Something else important happens.
Figure 2. Notice that the car is closer to the concrete barrier and I was about to disconnect and take over manually, but the car then proceeded to adjust and give more room to the left.
Can you see why the car behaved worse in the second photo compared to the first?
The other challenge is that in Europe (including the UK) cars should keep to the inside lane at all times except when overtaking slower traffic. Travelling in an outer lane with nothing on say a middle lane can be penalised.
it makes for more disciplined driving (overtaking only on the outside for instance) but is a challenge for any auto-positioning as the car cannot choose any empty lane.
Drivers in the US are so bad... they all want to drive in the left lane. I've found I can make better time on the outside lanes. Today I was driving on the Interstate and it went from 2 lanes to 3 up a hill. Everybody kept to the left. I moved to the empty right lane and passed them all.Correct, one of the problems with current TACC is that it will launch you overtaking other cars on the inside when a car you were following in that lane takes an exit and moves out from in front of you. If you had TACC set to a higher speed you will speed up and surprise other drivers. You can also be penalised for it. I can see this not being a problem in the US following a 'keep your lane' policy but with a 'keep your speed' system it doesn't work.
