Autopilot energy consumption - an interesting observation
ZeeDoktor
161
287
Sydney
I often drive in the country where there are distances large enough between chargers that it pays to actually figure out power consumption of all the consumers so as to avoid unnecessary stops or make it last that extra dozen km's for comfort. Using a CAN bus adapter I've been looking at how much energy the various subsystems consume by measuring the amps being drawn from the HV battery. It should come as no surprise that the HVAC is a hog, using several kW of power.
From sailing I know that the autopilot uses significant power for the servos (draining a deep cycle 12V / 300Ah marine battery in about 24 hours), so I was wondering how much energy does the Tesla autopilot consume? Now, much like in sailing, the Tesla autopilot will need some serious motor drive power for the steering, and then of course significant autopilot compute power - although I'm not sure whether that isn't always running (after all we get the dashboard visualisations whether AP is on or off). So while stopped at a traffic light behind other cars, I've switched the autopilot TACC+AS on and off again several times, each time noting the increase in battery drain from the HV battery. And it consistently increased the drain by about 2A at 366V, which means TACC+AS needs ~700W of power.
So next time you're getting confrontational messages from your car about not making your destination and you go into energy save mode and disable HVAC, you may also want to drive manually, which should save about 3km of range per hour of driving. Not terribly much, but it might just make the difference.
Munka
156
118
Perth
But.... You still have power steering when manual. The difference may actually be from the computer, but that is meant to run in shadow mode anyway.
Blue heaven
Fair Dinkum Tesla
Nov 25, 2014
1,143
1,360
South West Australia
With non autopilot it's power assisted steering, on autopilot it's completly power steering, not really much extra power draw especially on straight roads.
The extra computer power draw is interesting though.
Saghost
8,216
7,000
Delaware
That’s interesting. Given that the safety systems are running 100% of the time, and that the car uses the same systems to power the steering and brakes that it uses to assist you with them while you’re driving, I wouldn’t have expected any consumption difference.
Can you repeat the test driving along a road in a steady state?
Maybe there’s something odd about the situation while sitting stopped that’s producing your result.
