...it started to drift off in the opposite direction off the road...
1) The name "Autopilot" is designed so that if there's a crash, it's always human aviation pilot's or roadway driver's fault even when there's clearly the system is the cause in the chain of sequence that leads to the crash.
It's designed for those who are licensed to fly or to drive even in the presence of Autopilot.
2) In addition to the above, it's also in Beta. The expectation of Beta is it is not finished. It's easy to know that hardware is not finished but many people do not expect that when it comes to software or Tesla Autopilot.
For example, if the home construction said that my home is not finished then I am not surprised to look up the ceiling and see no ceiling but the sky. If the roof is not there, then that's because the home is not done!
However, when it comes to Autopilot, Consumer Reports were shocked that Navigation on Autopilot is far less competent than a human driver. They just don't understand that it's not a finished product just yet!
3) That said, I want to know what are the system's limitations so I install the camera to monitor the autopilot screen and the road so I can review later since 2017.
By reviewing it, I would learn what the
system's inefficiencies are and how I can learn to drive with it.
4) Back to your question of lane drifting, it could happen in early versions in very tight corner cases. Nowadays, I don't see that much at all.
When I let another driver used Autopilot, I observe lane drifting usually happened because the driver disabled the Autosteer with a manual torque. When the driver realized it, the driver would turn the Autopilot back on but unsuccessfully as evidenced by the still unlit Autosteer Icon. Thus, the driver then blamed the Autopilot for the lane drift and then reactivated the Autopilot again.
5) So, in summary. it is prudent to:
1/ just drive the way you've been licensed to drive. Don't let your car drift out of lane.
2/ Install a
camera documenting both the autopilot and the road if you want to know what happened.
