I was told at the SC that with a vin of 35000 I would have to wait until late 2020 for new FSD computer.
And that's USA!
As I am in the 26k VIN range, I wonder if they will go through your VIN before mine anyway. That does not bode well, lol.
Weaving on autopilot.
I had this on my 50.7 model 3. I took it into service today and they rotated the tires, checked the alignment.
They said the alignment was a little off and fixed it.
They also did a camera alignment.
I drove it home and the weaving is gone.
get about a 6" left to right and 4-5 second sinusoidal sway, it is very predictable and repeats 10+ cycles of slowing bouncing from left of center to right of center and back again in the lane.
I'm fairly certain AP would have hit the car next to me if I didn't prevent it from doing so.
W
Was this alignment done at your expense, or under warranty?
How old is your car and what is your AP version?
Regarding the weaving on the highway... while it's possible that ultrasonic sensor calibration is responsible for some of the weaving on the highway when other vehicles are present, I'm sure that's not the only contributing factor. On I-95 today with no traffic for a couple hundred yards, the car was weaving. There were no guardrails or other objects for the sensors to pick up. I stick by the theory that it's at least partially just an underdamped feedback loop for the visual-to-steering control system.
rededicate some of the resources that went into deep rain back into deep lane centering...
I'm 052xxx and have my HW3 install scheduled for March 4 in Maryland.And that's USA!Imagine the rest of the world, lol.
I've noticed some regressions on AP2.5. On a 2 lane "city street", the car seems to lose the lane lines because of faded asphalt and will freak out mid auto lane change and throw me back into the right lane. On NOA, I've had several instances where it freaked out on an exit that it used to be able to do smoothly before. Is the software being optimized now for AP3 and not working as well on AP2.5?
Hi everyone, first post here on TMC, but I'm on TOO and Reddit under the same username. I agree with everyone in this thread about AP having some notable regressions in the past 2 months. (I'm on HW 2.5) It's almost as if all the computing power that went to deep rain got taken away from basic lane centering and highway speed curve prediction. I noticed a drastic reduction in AP's "attentiveness" around 2019.40.1 that has yet to return; I override AP about once per 20mi now on the interstate for things such as forgetting to turn until it's scary, hunting the double width right lane after a merging on-ramp lane, and just refusing to stay in the center of the lane.
AP used to be the feature I would show off the most to passengers in my car and now I rarely use it with passengers because I don't know what it's going to do wrong anymore, I just know it has a much higher chance of being embarrassing than it was on 2019.36 and previous builds. Understeering the same curve multiple times which results in soft bouncing off the outside lane line or sling-shotting off the outside lane line are not features you want to demonstrate to others.
My car will occasionally get about a 6" left to right and 4-5 second sinusoidal sway, it is very predictable and repeats 10+ cycles of slowing bouncing from left of center to right of center and back again in the lane. It's like the lane is just a touch too wide for either camera to care until the car drifts into it's territory and then it'll redirect the wheel to steer the car back across the no-man's land in the center of the lane until it encroaches on the other side's territory.
On my commute home today I had a new experience. I don't know if this is a PSA for general autopilot use or if it is part of the recent lane centering regressions. It was raining and I was passing a 1-ton dually with a gooseneck trailer that was kicking up quite a bit of road spray. When I was about even with the front cab of the truck AutoPilot decided to dive bomb right towards the truck next to me. The right pull on the wheel was as aggressive as a modern AP lane change or re-centering into the double width merging lane pull that we've all experienced.
This was the first time that I'm fairly certain AP would have hit the car next to me if I didn't prevent it from doing so. My best guess is that the spray from the truck confused the ultrasonic sensors and the camera's lost track of the truck and the center lane line (it was clearly painted BTW). After the car lost track of the center line and the truck due to the spray I think it continued to see the outside lines of each lane and started to interpret the two lane highway as a single double width lane. I think the violent pull towards the truck was the same centering behavior as a merge lane, just with a 70mph pickup 3ft into its chosen path. I saved the TeslaCam clip but of course forgot to properly pause the CAM before ejecting it when I got home so my saved clips are the dreaded 594 byte nothing files. Has anyone else had this happen?
