Autopilot Issue
Discussion in 'Model X: Driving Dynamics' started by wqu06, Aug 23, 2017.
  1. wqu06
    wqu06 Member
    Oklahoma
    Has anyone not be able to activate AP on the highway after disabling it? It's happened a couple times but wanted to see if anyone else has had this issue. Sometimes AP will not come back until I stop for a period of time or >30 min.
  2. Padelford
    Padelford Supporting Member
    Seattle
    I haven't had this happen, but have you called the support line?
    I'd suggest trying to reboot the vehicle by holding down the upper buttons on each side of the steering wheel (above the thumb wheels). If that doesn't help, you should contact an SC.
  3. Magus
    Magus Member
    Midwest
    Yes, it's progressively improved with updates. It's a software thing. Essentially if there are a certain number of errors or such the system deactivates and one has to leave the car for it to reactivate (supercharging on a road trip).
  4. wqu06
    wqu06 Member
    Oklahoma
    Somewhat afraid to reboot while on the highway. I mentioned it when I had to drop my car off at the SC and they couldn't find anything wrong. It doesn't happen at the same stretch of the highway either, sometime it will let me activate and sometimes it won't.
  5. Magus
    Magus Member
    Midwest
    There isn't anything wrong with your car. It's the current state of development. This will get better with updates. Resetting your screen will do nothing.
  6. kort677
    kort677 Banned
    florida.
    did you get tossed into the penalty box for inattentiveness or going over 90 mph with AP enabled?
  7. bonnie
    bonnie Oil is for sissies.
    Columbia River Gorge
    That was my first thought, @wqu06.
    Did you disable AP manually (touched the brakes, pushed the stalk out, took over the steering) or were you kicked out of AP because you eaither accelerated and exceeded 90mph or ignored warnings to put hands on wheel? (No judgment, most of us have done one of those or both & learned we lost AP until we stopped.)
  8. Joe F
    Joe F FUD Buster
    Outside Philly
    Harmless from a drivability aspect. Had to do it yesterday when trying to navigate home, and nav got hopelessly locked into a "searching for supercharger" loop. Tried 3 times and got the same loop. Rebooted, and it worked first time. This at 75 MPH...
    Was low on charge and needed to make sure I'd have enough to make it without having to slow down.
  9. wqu06
    wqu06 Member
    Oklahoma
    Nope. One time it was immediately after I left a supercharger and got on the highway and AP would not enable for ~30 minutes.
    It's happened when it detected a phantom object and started beeping at me (this happened on my way to the SC and I told them the approximate time that it happened). It's happened when I manually disable AP and want to re-enable. It's happened after I supercharge and got back on the highway.
  10. Magus
    Magus Member
    Midwest
    Nothing is wrong with your car. AP2 disables after errors/faults that have nothing do with driver error. This will be less and sooner or later stop with a future update. It has significantly gotten better with recent updates. Resetting will not do anything.
  11. outie
    outie Active Member
    SoCal
    How did you confirm this will be less and sooner or later stop with a future update? Have you already received the said future update? Please tell us more.
  12. Magus
    Magus Member
    Midwest
    Experience and posts since getting my X earlier in summer. Drove long distances in the beginning and errors were relatively frequent. On a big road trip frequently lost the use of AP. Noticed in posts that this exact same experience happened. Then with updates on a different road trip, this behavior improved significantly. This was the exact experience others had reported with one of the significant updates (along with improved behavior and reduced ghost braking).
    Taking a break for supercharging or other reason will allow for the system to reset. But forcing the computer reset will do nothing to reset the autopilot behavior. It still happens on occasion with current software- once on a third roadtrip but far less frequently still.
  13. MGMDaware
    MGMDaware Falcor
    DC
    Can confirm same results with my Model S. This happened to me maybe 3 times while on a road trip. Resetting computer did nothing. Leaving the car parked and at rest seemed to fix it. This problem was resolved at some point after an OTA update (I think 2 updates ago). Have not had the issue since.
    Nevertheless, I feel your pain. It's really annoying for this to happen while on a road trip . . . . When you need/want AP the most!
