Autopilot Lane change
Discussion in 'Model S: Driving Dynamics' started by desidon, Jul 10, 2016.
  1. desidon
    desidon Member
    TX
    Folks... Have not been able to get the car to lane change.
    I am on autopilot, give the turn signal, no car ahead or behind on the other Lane..... The car does not change lanes.
    I have not get this to work since I got the car.
    Autopilot works, auto Park works(perpendicular). Have not tried the parallel Park yet.
    What am I doing wrong?
  2. AndreyATC
    AndreyATC Member
    New City NY, USA
    Do you fully press the turn stalk or just temp 3-blink mode?
    It has to be all the way until lane change complete
  3. pdxrajiv
    pdxrajiv Member
    Portland, OR
    The lane change feature has to be enabled explicitly in the settings screen.
    Have to checked to see that it is turned on?
  4. desidon
    desidon Member
    TX
    I press it like I do when I change lanes. So nudge it up or down and leave it...... Am I doing it wrong?
  5. desidon
    desidon Member
    TX
    I did not know this either. ...Feel like such a noob!
    I have been through settings many times....never found this setting. Where is it located?
  6. desidon
    desidon Member
    TX
    Found the setting and executed a successful Lane change. Thank you guys.
  7. ilovemycoffee
    ilovemycoffee MS 85D HW1 Late 2015
    Coos Bay, OR
    If you have other drivers with their own settings, they will also need to turn on the lane change setting
  8. Boatguy
    Boatguy Member
    SF Bay Area
    It works either way. You can use the momentary contact position, holding it up/down until the change is completed, or you can use the full up/down which will stay until you push it back the opposite direction. I prefer to use the momentary contact position, but you have to hold it until the lane change is completed, if you release early, the MS will swerve back into the original lane.
  9. pdxrajiv
    pdxrajiv Member
    Portland, OR
    I do wish that the lane change assist had an option to set how long to blink the intent before changing lanes.
    The way it currently works, it starts blinking and immediately proceeds to change the lane.
    I like to declare my intent by turning on the lane-change indicator, wait a few seconds (2-4 is ideal, depending on speed and traffic density) before actuating the lane change.
    Currently, there is no way to configure this behavior.
