Autopilot + overhang = warning?
Discussion in 'Model 3' started by paulvinh, May 29, 2018.
  1. paulvinh
    paulvinh Member
    Los Angeles, CA
    Route to work today on autopilot when suddenly it gives out a warning while passing freeway overhang. Car in front and back was about 5 car distance and only a semi-truck on the lane next to me to the right. Didnt seem like anything was happening.
    I have a dash cam video but cant upload here because of .mp4 .mov file extension.
  2. WallyP
    WallyP Member
    Orange County, CA
    What was the warning, and what firmware version are you on?
  3. paulvinh
    paulvinh Member
    Los Angeles, CA
    The 3 loud beeps that it does, like it was predicting an accident or something.
    2018.18.13
  4. WallyP
    WallyP Member
    Orange County, CA
    I'm assuming you mean this happened in EAP?
    I've experienced sudden deceleration while passing an underpass, and without a warning. However, now that I am on the new 2018.18.13 software I have had no incidents. I'm wondering if the audible beep warning is a new EAP feature in the firmware?
  5. Zaphod
    Zaphod Galaxy President (former)
    Austin, TX
    Was there a shadow being cast on the road?
  6. paulvinh
    paulvinh Member
    Los Angeles, CA
    Yes, EAP.
    Underpass thats the word, couldnt think of it. The audible beep really shooked me. I’ve driven the same direction before with no audible alert warning so it could be new to firmware.
  7. paulvinh
    paulvinh Member
    Los Angeles, CA
    Yes
  8. Trips
    Trips "Boring bonehead questions are not cool. Next?"
    Omaha, NE
    This is a known issue that has been around since the beginning. It happens on sunny days where the car thinks the shadow is another car. Normally the car brakes so maybe it is getting better by just giving the warning.
  9. ebmcs03
    ebmcs03 Active Member
    So Cal
    But it didn’t slam on the brakes? That’s an improvement. Before people were reporting it slamming on the brakes and if someone was behind would rear end them.
  10. paulvinh
    paulvinh Member
    Los Angeles, CA
    It did slow down but i dont believe that it slammed on brakes. It shooked me so I got out of autopilot right away.
  11. Zaphod
    Austin, TX
    As @Trips states, the shadow issue has been reported a few times happening to people. It seems to cause confusion momentarily for the cameras and create false-positives. Hopefully the software or AI will improve over time to hopefully eliminate this scenario.
  12. WallyP
    WallyP Member
    Orange County, CA
    I'm not sure if it is actually a shadow issue. I experienced the EAP error in full sunshine with no overpass, signage, or other obstacle to cast a shadow (unless an airplane flew over that I was unaware of).
    In any case, I'm hoping the audible beep warning in the new software helps fix this problem.
