Recently took a 1200 mile road trip, mostly on EAP (v9). It was generally a super impressive first experience with EAP, but curious about a few things:
1) Now that the car is using all cameras and is capable of identifying semi trucks, do we think it will ever give them extra “space” in a future update? I was a bit shocked at how close the car would allow trucks to come / how stubbornly it sticks to the center of the lane even when the ultrasonic indicator arcs on the display were red.
Is it currently safe to assume that the car would actually move to the left or right if another vehicle intruded into the lane? I tried to trust as much as I could / avoid taking over and had some close calls but at no point was I able to observe EAP deviate from the center of the lane despite trucks coming super close more than once.
2) Had 3 phantom braking events but couldn’t detect any pattern or cause; are any known?
3) The situation described in the manual wherein the car will actually aggressively accelerate into a stopped vehicle if a car you’re following moves out of your lane revealing a stopped car in front of it is real and is scary. I paid close attention throughout the drive as required and as such was able to avoid a close call but wow was this unsettling despite being a known limitation. Curious to hear other’s experiences with this.
4) Cars in adjacent lanes close behind you don’t show up in the display’s visualization until they are actually in your blind spot. I understand that the display isn’t necessarily the same data actually used for driving. Has anyone been able to figure out if the auto lane change / blind spot warning will keep you from cutting someone off if they’re somewhat close behind you but not yet on the display (eg is it safe to just not check your blind spot and use the turn signal to trust the car to change lanes - I would never do this, but want to understand the car’s technical abilities and limitations).
