If I set autopilot on in a 30 limit the TACC speed stays at 30 when I enter a 40 limit (but speed limit sign on the right does increase to 40).
That was my experience with AP1 too.
So the car slowed down when the speed limit was reduced, and sped up when the speed limit increased.
Again, same on AP1.
Had to set TACC before getting into the (30) for it to then change TACC (i.e. and accelerate) when leaving the Limit (or the Limit increased to e.g. (40) )
I have tried setting TACC on in a (40), driving into a (30) [
it should reduce speed] then back into a (40) [
it should increase] but then what about on leaving the (40) - I wonder if it would it increase to (60)? I expect that it will be limited at whatever was the speed when TACC original engaged.
I find it pretty unnerving accelerating to 60, coming out of a (30) or (40). The fact that I might have had TACC set to 60 on the way in is not a reliable indication that 60 is correct for the road after leaving the limit!
It’s definitely GPS driven, not reading the speed signs.
To clarify what I wrote / meant:
"speed limit change is also displayed" as in "on the dashboard", and that comes from a GPS database [of speed limits] on AP2 (
not relevant, but in AP1 the speed sign was read instead). That GPS database may be "off" by some distance, or indeed, as you say, out of date or just plain wrong
Separately from that the TACC speed may automatically change to match ... or not. My theory being that it does on single carriageway, but does not on dual carriageway.
