My collision alert was indeed set to "early" as well when it happened. My instinct told me I should change to medium after my car stopped on freeway. Then I saw your post. I hope this solves the issue. Regardless, the car shouldn't be doing this even when forward collision is on "early". This is a serious safety issueI received my car back from service today. They resolved the 12V issue but stated there were "no faults detected" in the autopilot and AEB systems. I pushed for a better explanation and it seems as though they never actually looked at the logs to determine the cause? I was told they will look into it more and get information from the engineers. One suggestion they had was to make sure my collision alert was not set to 'early'.
However, the initial response was "there is nothing wrong." I just can't accept that my car slamming on the brakes in the middle of the highway == 'nothing wrong'.
are you still experiencing "ghost car" and brake slamming when you set it to "off"?That setting has no effect on braking. Mine is also set to off because of too many false positives. Alarm fatigue - Wikipedia
While it seems like the issue has improved over the last 6 months, TACC still gets periodic false readings causing the car to rapidly slow down for now apparent reason. On a 35 MPH surface street near our house, there's a section of the road where TACC quickly slows down - every time - the only thing I see different in that section is a short stretch of pavement where they repaired it - and the new pavement is a slight different color than the rest of the road.
It's likely the software is being overly conservative - and if it thinks there is an obstacle in the road - it's slowing down, just to be safe. And as they get more data and refine the algorithms, hopefully they'll get this fixed.
The other major problem is the many errors in the speed limit database. While this doesn't impact TACC once TACC has the speed set, it does have an impact while AutoSteer is enabled - causing the car to rapidly break if the software believes the speed limit has dropped below what AutoSteer supports - something that can surprise other vehicles that are driving at full highway speeds...
... If I get into an accident because of this, Tesla will have to be responsible. Because it happened so fast, I am not even sure if i can save the car from being rear ended if it happens again.
same here with 50.3 twice on freeway now...Mine did this today for the first time too - 2017.50.3 AP2. On the freeway, nothing around anywhere - collision alert and full hard braking out of nowhere. Scary... glad nobody was behind me.
