>>However, touch the 70mph symbol on the screen and it goes back up.<<
Not on the S it doesn't!
Oops sometimes it feels like this is an M3 forum, apologies.
One thing I did realise yesterday was that some speed limits which have only been in place for a year or so, are not recognised and the car uses the original limit.
Is that map or GPS at fault?
Yup. Must be down to the wrong sort of leaves on the road or the wrong sort of clouds in the sky. Or even the wrong sort of dust on the cameras!Reading through this thread I think I have witnessed most of the scenarios played out in my (non FSD) M3 LR. Unfortunately I have not documented the settings I have used and I keep changing them to try and find a Derek (happy medium).
I have come to the conclusion that while the speed setting and maintenance there of is systemically related to a combination of settings, external (detected) factors, hardware and software versions, the basis for the decisions and alterations the car makes is not something I can fathom, so I’ll just sit back and enjoy the ride and not worry too much more about it![]()
Couple of posts here mentioning auto-adjust for speed limit changes tooMaybe some progress on 2020.16.2.1
Yes. It’s really weird and at the same time unintuitive and clunky. on my previous car, Lane keep remained active once engaged. If I indicated to change Lane it was temporarily disabled and then resumed once the indication was stopped. Having said that, it had no bearing on speed but you knew where you stood!I joined the club today
5 times the active max speed changed on its own. 4 times on single carriageway when the speed limit changed from 60 to 30. I thought it may have been because there was a car in front, but driving back through the same limit change with nothing ahead and it did it again
the 5th time was on a dual carriageway where an A road becomes a motorway. The limit doesn’t change but the max speed changed down to the 70 limit as I entered the motorway.
I still have speed assist set to relative +0
