Autopilot won't work- Cameras require alignment message.
Discussion in 'The UK and Ireland' started by Wakeywarrior, Jun 6, 2019.
  1. Wakeywarrior
    Wakeywarrior Member
    UK
    Earlier in the week downloaded the latest maps I assume as could then suddenly engage navigate on autopilot which had been greyed out for a few weeks. Running 2019.16.3.2 . Nav on autopilot and autopilot ran a few times after it installed the maps.
    Then suddenly the car stopped detecting any other cars, albeit it detects some lane markings.
    Autopilot does not work. No steering wheel icons and when you try and engage it, it says the cameras need aligning in the instrument cluster.
    First time it did it, I turnedoff Sentry and did a deep reset. Started working the next morning
    Then when leaving work again, same issue. No cars detected and says cameras require alignment. Tried resetting 3-4 times but still won't work.
    Anyone else had this message?
  2. Peteski
    Peteski Active Member
    UK, Milton Keynes
    I haven't had any warning messages, but I've noticed recently with the latest software that AP sometimes takes a little longer to initiate when setting off from home. Yesterday for example the AP icons didn't appear on the dash until I'd driven a mile down the road. Maybe there is some calibration or something going on? Nav on AP is working too. I'm also on 2019.16.3.2 with Sentry active except for home. However I have switched off dash cam while driving as it was causing issues with Spotify streaming.
  3. Terry_B58
    Terry_B58 Member
    Lancashire. UK
    You will most likely need to book an appointment with your local SC. You can book it with the App
  4. Wakeywarrior
    Wakeywarrior Member
    UK
    I also noticed when it was working, it didnt 'switch on' until 100 yards from home. It would randomly work and not work. Had it into service centre for a calibration today.
  5. craigger
    craigger Member
    San Diego
    Hi - old thread but in case anyone else has the problem. I have a 2020 Model S (that I just picked up yesterday) and I got the exact same behavior as originally described today. I have an appointment for the service center next Monday (6/8) and I'll update this thread with the resolution.
    Here's what my dash shows:
    A little frustrating to have this go wrong on day 2 of ownership, but I suppose it's better than 2 days after the warranty expires!
    -craigger.
  6. VanillaAir_UK
    VanillaAir_UK Moderator UK and Ireland
    Surrey, UK
    You have to drive your car for up to 100 miles to allow them the calibrate although many do calibrate much sooner than that.
    Have the cameras calibrated - iirc on our Model 3, there was a ring around the autopilot icon indicating calibration progress.
  7. Durzel
    Durzel Active Member
    Bath, UK
    Is calibration the same as "alignment" though? Alignment sounds like a fault.
  8. craigger
    craigger Member
    San Diego
    Yes, calibration was complete and I was using FSD and Autopilot the day prior. I set up an appointment for mobile service but they said they needed to fix it in the SC. I'll update this thread with the outcome.
  9. JoulesATX
    JoulesATX New Member
    Austin
    craigger - any update on the outcome? I have a 2020 Model S that I just picked up on Monday and I'm having the same issue. Calibration was complete and FSD and Autopilot were working fine for one full day. Tuesday, it stopped working. I have a mobile service appointment scheduled for next Tuesday.
  10. craigger
    craigger Member
    San Diego
    It ended up being the front camera alignment. A bit of a hiccup - I got it 'fixed' and had to wait for the camera calibration to complete. Had the same issue - wasn't happy. Called the SC and they scheduled me next day - went through another camera calibration and it has been fine ever since. I'm pretty sure they're going to re-schedule you for the service center as I don't think they have the right equipment to do the alignment with the mobile service.
    Hope it all works out for you.
    -craigger.
  11. JoulesATX
    Austin
    Thanks, I appreciate the info. I'll post an update with the outcome.
  12. JoulesATX
    Austin
    You were right. They re-scheduled me for the service center. It ultimately ended up being a problem with the front camera alignment which they were able to retrofit with a new mount plate. It was at the service center for 2.5 days, but once they started working on it, it only took them about 4 hours to diagnose and service the issue. The first two days the car was just sitting and waiting for an available technician. They were pretty backlogged here in Austin.
    From the invoice:
    Diagnosed and Completed Pre-Calibration Forward Facing Camera. Performed Forward Facing Camera Drive Cycle Calibration. Performed Retrofit 2nd Generation Autopilot Forward Facing Camera Pitch Carrier. Verified Proper Operation.
    Correction: Pitch Carrier - Camera - Forward Facing - 2nd Generation Autopilot
    Parts Replaced or Added: TRIPLE CAM RR VIEW MIRROR MOUNT PLATE -1.2 DEGREE(1126328-02-A)
  13. craigger
    craigger Member
    San Diego
    Glad you got it sorted out! Although 2.5 days waiting before they even looked at it is pretty unreal. I hope they gave you a loaner in the meatime.
  14. Wesmosis
    Wesmosis Member
    Edonmton AB
    Thanks for your update, I'm having the same message after 3rd party windshield replacement!
  15. Wesmosis
    Wesmosis Member
    Edonmton AB
    Thanks for the followup.
  16. Medved_77
    Medved_77 TM3 SR+ | MSM+Black | No FSD
    Scotland
    In software update 2020.32.1 you'll be able to reset the autopilot calibration yourself from the service menu.
    Hopefully that update will be with us soon.
  17. HenryT
    HenryT Member
    UK
    As an aside, I had a similar problem with my car twice - it turned out to be a problem arising from leaving the car parked facing towards the setting/rising sun. Evidently, continued exposure to direct sunlight at a particular angle can throw the sensors out for a while.
    Each time, mine managed to come to its senses after a short while and a couple of re-starts.
    I have seen reference to little sun shades being used while parked up to prevent this.
  18. Wesmosis
    Wesmosis Member
    Edonmton AB
    Unfortunately I had to drive it to Calgary (nearest SC) and Tesla did the camera aliment in 2-3 hours for free.
  19. Medved_77
    Scotland
    Did the in car function not work or is it a requirement that a SC still has to calibrate the cameras following a windshield change post 2020.32?
