Does AP2 at present change speed as per speed limit? Does it slow down when moving from higher speed limit to lower?
What about on highways? Speed limit changing from 70mph to 60mph.Only in terms of staying no more than 5mph above the speed limit on local roads with autosteer. So if you’re going 40 on a local road with autosteer and the speed limit drops to 25, it’ll automatically adjust down to 30. But not vice versa.
There are many who overestimate Autopilot's capability and also counting on its non-existent speeding ticket avoidance with automatic-speed reduction for posted speed limits:
Tesla Autopilot gets its first speeding ticket
I think that capability is easily implemented in future because it's just a matter of algorithm!
While using Auto Steer and changing freeways and there is a dedicated lane I use the auto change lane feature to get into the lane. However, when making the turn onto the new freeway it will sometimes reduce the speed limit. But since the car will not reduce the speed limit I go into it too fast. What I general do (if I want to play with the feature) is to use TACC to reduce the speed to match how fast I want to hit the turn. I have wondered how it will eventually work. EAP is supposed to take you from on ramp to off ramp (assuming using navigation) so it needs to be able to handle this at some point.
Presumably, it'd need to read speed limit signs.
...AP2 S90D and it does not change speeds...
AP2 does automatically change speed in specific conditions:
When I first used AP2 on an undvided road that has a posted speed limit of 55 MPH and down to 40 MPH as well as a caution speed of 30 MPH on a curvy stretch, it just kept going 55 MPH and I doubt I could make it with that speed so I had to manually slow down myself.
Later on, AP2 has automatically slowed down on its own to 36 MPH on that same curvy stretch but that is still higher than the posted caution speed of 30 MPH.
If I now try to increase the speed on that curvy stretch, it would say something like "AutoSteer Speed Restricted".
Looks like AP2 is geofenced with a restricted speed at certain locations for safety that has nothing to do with speeding ticket avoidance algorithm.
