My Autosteer has always been so-so in that it does not consistently disengage when I apply a turn signal to change lanes. Now with Automatic Turn Signals, I am getting a little more data and am curious if others are experiencing similar behaviors...
During my drives, I think that Autosteer disengages less than half the time when I apply the turn signals. It does not matter if I do the partial or full turn signal stalk engagement. Some drives it is intermittent, and then yesterday's drives never disengaged Autosteer with the blinkers. (Other drives Autosteer will properly disengage nearly every time.)
What is interesting is than when Autosteer does not disengage, the turn signals only flash 3 times. But, when I use the blinkers without Autosteer, the Automatic Turn Signals work as described 100% of the time (will continue flashing until I complete a merge, lane change, or fork maneuver).
So, it seems like there is something in the code that intermittently blocking the turn signal trigger from notifying the Autosteer logic to disengage. And this seems to cause a 3-flash of the blinkers when Automatic Turn Signals is on. (If the car was not a 100% computer, I would suspect a bad switch or component.)
I am curious if others are seeing intermittent Autosteer disengagement symptoms and if you have noticed a correlation with the Automatic Turn Signals misbehavior?
