Don't be silly.
There is nothing wrong with the road. Except for the lane markings.
And the fact it's explicitly not the type of road AS is intended to be used on.
But I know you never let documented facts from the user manual get in your way
Oh, don’t be so self-righteous and smug. I’ve got a new car:
Then you should probably read the manual. Especially the parts on systems and tech new to you.
That's not smug, that's basic safety and common sense.
I’m having fun trying it in various situations, and am reporting an interesting result.
I don't really find "did not work right in a place it's explicitly not intended to work right" super interesting.
YMMV I guess.
Having purchased FSD, I’m interested in what Tesla is going to have to overcome to make it succeed someday
The HW3/FSD code base isn't running on the car yet.
Trying to draw any conclusions about its abilities and behavior from the legacy 2.x code it's running now is pointless.
I’m also hoping this observation will somehow get forwarded to the folks who are working on the program.
It won't.
Nor would it help- since again it's an entirely different code base that will be in use to actually handle situations like yours.
From the manual: "Warning: Autosteer is intended for use only on highways and limited-access roads with a fully attentive driver."
It's a divided highway with limited access in that section.
No, it's not.
There's a stop-light at that intersection- it's clearly visible in the photo. (And intersections != limited access)
But even without the intersection- Autosteer doesn't do stop lights at all.
(On a related note-federal guidelines on controlled access freeways require free-flowing traffic with all cross-traffic relegated to under and over passes so there's no conflicts with the main line of traffic that need to be regulated by traffic control devices like stop signs or
stop lights)
A u-turn intersection is not an on/off ramp- because it has cars coming
across traffic to complete the U-turn.
A situation explicitly not supported by AS.
Again the explicit assumption of AS is that all traffic is free-flowing in the same direction you are going...
Cross traffic isn't a thing it understands, and isn't intended to understand- so any road situation marked for any sort of cross traffic may well cause it issues since it's not intended to work there in the first place.
Just like this example
