autoto
Discussion in 'Hong Kong' started by Mille Pun, Apr 7, 2016.
Tags:
  1. Mille Pun
    Mille Pun Member
    HK
    Autotoll on X and 3
  2. Mille Pun
    Mille Pun Member
    HK
    Wrong title
    My Q is X and 3 without nose, and how should HK owner place the autotoll? :cool:
  3. markwj
    markwj Moderator, Asia Pacific
    Hong Kong
    Really too early to tell. Just guessing at the moment. At least in Hong Kong we have lots of options because our tags don't have displays or buttons to be pressed.
  4. bobhammer
    bobhammer Member
    Hong Kong
    I still haven't gone to the service centre to install the autotoll pass, currently, I just hold it out of the window with my barehands lol
  5. FequalsMA
    FequalsMA Member
    Hong Kong
    not sure if this has been tried on the M.S, but will sticking it on the underside of the frunk work?
  6. ediot
    ediot Member
    HONG KONG
    it isn't hard at all to "install" it yourself. all i did, was:
    1. put the autotoll thinger in a sealable bag. those you use for leftover food etc will do, all it does it protect the thinger from rain / sand etc.
    2. open the frunk (front trunk)
    3. with your hands, just press down on the "bottom lip" of the car, and the front plastic "grill" will pop out. be a little careful since there's a wire or two attached to it.
    4. just tape the autotoll onto the back of the plastic grill, then pop the grill back onto the car
    5. close the frunk
    6. drive into the sunset via autotoll, smiling.
  7. deku
    deku Member
    Hong Kong
    The Front bumper should be made of plastics. I believe Tesla service in Hong Kong should be able to help owners with that.
  8. OreotheCat
    OreotheCat Member
    Hong Kong
    If you taken notice on the NEW owner's manual published Apr 5, you will find something now about installation of Autotoll
  9. mingazoid
    mingazoid New Member
    Hong Kong
    Not sure if this has been answered already, but I have a new Model S, which does not have the black plastic "nose cone" cowl. Where is the best place to put the autotoll transponder? I stuck it on the windshield as suggested by the Tesla store personnel, but 9/10 times it does not register when I cross the toll booth. Any suggestions aside from holding it out the window every time?
  10. AnubisDenko
    AnubisDenko Member
    Hong Kong Island
    I installed it next to the mirror in the black area as described in the manual.
    The actual trick was then to not drive faster than 40 km/h through the toll station. If I went faster it didn't work but otherwise always correctly registered.
    So it seems the signal is quite week that goes through the windshield.
    Cheers
    Oliver
  11. garethmchau
    garethmchau Member
    Hong Kong
    Has anyone tried sticking it on vertically instead of sideways so the whole thing is in the black area? Otherwise, like Oliver says I have to drive v slow through the gate for it to register.
  12. ediot
    ediot Member
    HONG KONG
    my tesla is the older gen one with the black plastic nosecone, and i have my autotoll hidden in there. accidentally drove thru a toll station at between 75-80km/b (oops), it still registered.
    apparantly you can wrap aluminium/tin foil behind the autotoll nugget if you stick it on the windshield to amplify it, but i haven't tried it myself.
  13. garethmchau
    garethmchau Member
    Hong Kong
    I stuck the tag on vertically to align with the black bits above the mirror ignoring the wrong autotoll advice not to and it works a dream. I can speed past toll booths now.
    This is for facelift version by the way.
  14. jl04
    jl04 Member
    Hongkong
    May sound stupid, but if it matters for which side of the tag being place upwards? would you mind sharing a picture of that? I want to copy your method.
  15. garethmchau
    garethmchau Member
    Hong Kong
    On the right hand side. I'll post a pic when I'm back in HK in a fortnight.
  16. AnubisDenko
    AnubisDenko Member
    Hong Kong Island
    I tried what Gareth recommended and it seems to work quite well. Drove through Western tunnel today with 55 km/h and no issue at all. Fingers crossed that it works in all the tunnels without issues now.
  17. tc720
    tc720 New Member
    Hong Kong
    For Model X, it should be fine using the autotoll, Following is what I found in the Tesla Model X user guide:
    When attaching an RFID transponder (used by many automated toll systems) inside Model X, locate the transponder in the topmost area of the windshield as shown. This ensures best results and minimizes any obstruction to your driving view.
  18. canon
    canon Member
    Hong Kong
    Anyone has actually installed the tag on Model X?
  19. cwsn2
    cwsn2 Member
    Hong Kong
  20. flyingbathtub
    flyingbathtub Member
    Hong Kong
