agentsmith1612
Hello, I am new here in the forum.
And I want to know what they have done exactly for the range mode in the model S.
If you put the car into range mode and charge it, the upper SOC increases to an higher level ?
Then if you drive in the range mode the bottom SOC is lower ?
All in all the SOC Level on the top and at the bottom go to a little higher/lower values ?
Is that the right explanation ?
And are there any factors in range mode that will reduce, like the cooling or heating for battery or the engine power ?
Imagine you plan a long trip and take the car in the evening into range mode and plug it in, is there morge "damage" for the battery to be the whole night into range mode (and fully charged) as in standard mode (not so full charged) ?
Last but not least, for the Roadster I have read that there are owners that plug the Roadster in at the evening but the "charging plan" is programmed in this way that the charging ends up 30 min before the owners get to work in the morning of the next day, because they assume a longer life time of the battery to be not so high charged at night (this owners always use standard mode).
Are the any charging issues for example thze balancing of the cells ? I read in the internet for the roadster that if you take range mode for charging, you have to be sure that the next charge is in stadard mode and you have enough time, because of balancing the cells.
