I’m still surprised at my lack of range
Lack of range (on a long journey)?, or "Fuel consumption" (in terms of overall cost-of-motoring) ?
If comparing against the statutory WLTP etc. figure the max-range is pants.
My view is that the only range that matters is on "out of range days". For me most of those are hammering along the motorway, hour after hour, at 70-plus-a-bit. If I'm just pottering around the countryside, or nipping to the shops, I'm not going to run out of juice. I get home and plug in.
Whereas the WLTP etc. tests are combined-cycle driving. Some slow, some fast. Which is fine for "What would it cost me, on average, to fill up the car" but that's a hang over from ICE cars and useless for "How far can I go on the motorway"
Also, you can't realistically run it until empty. So you can start your journey at 100% and then fill up at 10%. That's only 90% of your motorway-range.
Then when you stop you fill it to 80% (70% would be more efficient, 80% doesn't slow down that much, above 80% slows down a fair bit,, and above 90% charging slows down a lot)
So your 2nd (and subsequent) leg is 80% to 10% which is only 70% of max motorway-range.
And that's assuming that there is a Charging Stop exactly at that point in your journey.
Each leg is still a couple of hours motoring ... so when driving to the Alps, for example, my Model-S will do 2h30m between charges at 130 KPH. But because Superchargers are not perfectly placed my stops vary between 1h30m and 2h10m. Actually I arrive far more refreshed, stopping every 1h30 - 2h10m for 20 minutes each time and stretching my legs (and emptying my bladder!). On a 12 hour journey it adds about an hour compared to when we just swapped drivers and pressed on - and arrived knackered.
Personally I think the test should be "Range hammering along the motorway" so that on those days you know how far you can go.
Using ABetterRoutePlanner with some reasonably pessimistic parameters it reckons Motorway Range for M3LR is 201 miles - 334 Wh/mile.
If I set max speed to 50 MPH that changes to 285 mile range and 234 Wh/mile
Then there is cold, wet and windy weather. In Winter on a long (single-leg) journey I reckon to have 10% less range, and that's assuming that I pre-condition the car, off the mains, before I leave. If I have to do that off the battery then I have even less range. Bad news for the travelling salesman in Winter who stops at each Client for an hour - during which time the battery gets cold, and every time setting off has a significant energy-penalty.
Slowing down increases range - slowing from 70 MPH to 50MPH is very significant. But the wet weather aspect is different. Slowing down helps with aero, but not the wet. Still got the same number of miles of water to push out of the way. Same in an ICE car, just with its much greater range it isn't so noticeable.
