Average SOC affects longevity?
insaneoctane
3,369
5,184
Southern California
I think I read that the ideal SOC to maintain your li-ion battery at for maximum life is 50%. That's not usually practical because you're not using half of your battery's capability (half you range)
I usually charge to 80%, and my daily commute uses approximately 20% each way. I plug in each night. I just wanted to see what my use case results in for an average daily SOC for my battery....
Turns out I'm doing pretty good. I was thinking of maybe charging to 90% and skipping charging every other night, that's what really got me thinking. That resulted in 41% average and the inconvenience of having the end of day 2 at 10% SOC. I'm happy with my charging schedule and happy with my average SOC!
timk225
2,017
1,051
Pittsburgh
I wonder if Tesla knows the lifetime average SOC for our batteries. They track lifetime KW used and Wh/mile already, so it should be easily done.
jerry33
Mar 8, 2012
19,516
21,710
Texas
That's true for storage. The beetles in the pudding are that for a given amount of power output, more heat is generated at a lower SOC (basically what you want to do for long battery life is to avoid heat). So it's best to drive above 50% rather than below 50%. Also there's no real data showing that there is a measurable difference in battery life in a Tesla that's charged to 80% or 90% as opposed to some other lower number. Most of the articles on battery life use RC car batteries as a reference.
insaneoctane
3,369
5,184
Southern California
Tesla batteries are fairly new in the industry, so I will conceded your point that no Tesla-specific data exists from 80-90%, it does seem reasonable that Tesla batteries, which have generally common chemistry, will follow general li-ion characteristics (like charging to 100% isn't good, or very low charges aren't good, etc). It's fairly well documented that keeping li-ion at 50% SOC results in the least degredation and maximum life.
bedoig
477
703
The Woodlands, TX
It would be cool in some ways if Tesla released detailed data, but obviously they have an incentive to just say charge it to 90% and don't worry about it. My guess is the differences are close enough to negligible to justify their stance. My guess is that over an 8-10 year period the difference between a "set it at 90% and don't worry" battery vs a "micromanage for optimal lithium ion life" battery are less than 5-10%. That's purely speculative based on reading for a number of years, but that's the thing, we don't really have fleet level hard data.
I'm a set it at 80% and don't worry guy...
SSonnentag
Rocket Scientist
Apr 11, 2017
1,709
2,161
Arizona
I don't think it's the average state of charge being at 50% that benefits the battery, but the lowest standard deviation from 50%. Being at 90% is no better or worse for the battery than being at 10%, both are 40% off from the ideal battery state of charge.
Charge to 51% and drive only to 49% and then plug in again and your battery should outlive us all. :D
Reactions: vickh
darth_vad3r
Well-Known Sith
May 6, 2019
1,574
1,119
Canada
I like the average for the day by hourly breakdown.
Would be nifty to have an automatic calculation by giving a few inputs: charge target, charge rate, charge time, leg A duration, leg A consumption, leg B duration, leg B consumption.
I guess that’s 7 inputs. Hmm, that’s missing stay duration. So 8? Oh I’m still missing the delay to scheduled charge. 9 :)
So a weighted average of 5 stages, 6 I guess with a post-charge/pre-drive stage:
  1. pre-charge aka ante-charge (ac)
  2. charging (c)
  3. post-charge (pc)
  4. drive leg A (a)
  5. stay (s)
  6. drive leg B (b)
SoC Average (Savg) = (1/24) * (Dac*Sac + Dc*Sc + Dpc*St + Da*Sa + Ds*Ss + Db*Sb)
Where Dx = Duration of stage x in hours, Sx = SoC % (or average) over duration Dx
It’s nice to keep this lower rather than higher (closer to 50%), but as someone else mentioned there are also other considerations like the fact more current is required at lower SoC to drive so that can generate more heat during use.
