AWD front motor sounds
Garlan Garner
Banned
Mar 31, 2016
11,351
6,062
Chicagoland
The motor whine is due to the different motor technology. The front motor is an AC Induction motor with lots of eddy currents + iron core losses. The rear motor is far more efficient switch reluctance motor that has literally zero iron core losses. The "whine" we hear from the front motor is likely from those eddy currents.
I had an uncle named Eddy. Honestly I did.
He was really nice.....just like the eddy sounds.
Go figure...
paranoidroid
182
173
San Francisco
I hear it and I love it.
So to confirm, you hear a faint pulsing whrr-whrr sound that varies with speed like in the video I just posted? I think we all expect a steady whine but many hear a pulsing whine at certain speeds (what some may be describing as beeping?).
It's mostly evident when the car slows to around 33mph in the video I posted.
Garlan Garner
Banned
Mar 31, 2016
11,351
6,062
Chicagoland
So to confirm, you hear a faint pulsing sound that varies with speed like in the video I just posted? I think we all expect a steady whine but many hear a pulsing at certain speeds (what some may be describing as beeping?).
Oh wait...no. I don't hear a pulse.
Just the aged fine whine....
You need a decanter for your whine....lol Just kidding.
AlanSubie4Life
Efficiency Obsessed Member
Oct 22, 2018
8,973
10,695
San Diego
I found a video of someone recording the front motor pulsing sound that I hear. Turn the volume up because it's faint. It's most evident around 0:13-0:15 when he's at 33mph.
It's a faint high pitch pulsing - and not a steady whine like you may hear instead at higher or lower speeds. The faint pulsing sound almost sounds like a bad bearing and happens at certain speeds.
As far as I know this is completely normal and I hear it too. Is this the same sound others hear?
It's hard to say, but this doesn't sound like what I'm hearing exactly. It's possible that at 33mph it sounds similar but the video doesn't go on long enough.
Whine - the more amps, the louder it is - Good in my book. I like it. EDIT: Also probably higher pitched.
Quiet pulsing noises, particularly when not under load/coasting - these are quiet and ok for me.
Quiet gear noises at low speed - Fine in my book. Have to be going pretty slowly to hear the gears (or whatever it is - sounds like a very very quiet, less whiney version of an ICE car in reverse.)
Roaring/droning (seems to be from the front motor area, it doesn't seem to be tires or dependent on the road surface) between about 37mph and 41mph - Not great. It's not super annoying, but if I'm not playing music I notice it, and deliberately avoid those speeds.
paranoidroid
182
173
San Francisco
I guess the best way to describe is is to try to record the sound like in the video I posted. The sound I hear is specifically the pulsing whrr-whrr that if you start the video I posted at 0:12 you can hear at 0:13.
AlanSubie4Life
Oct 22, 2018
8,973
10,695
San Diego
Yeah I've been meaning to get around to it, but I haven't because I never remember to do so, and then it's a safety issue to try to do it at 40mph on the occasions I do remember. It's also not that important and I haven't had passengers comment on it. One of these days!
Garlan Garner
Banned
Mar 31, 2016
11,351
6,062
Chicagoland
My whine is different.
The more amps..the higher pitch it is.
AlanSubie4Life
Oct 22, 2018
8,973
10,695
San Diego
Mine definitely increases in pitch as well, I think as speed increases. But I think the more the go pedal is mashed the louder it is. Like I said, I like this sound! It's great.
I guess I can pay closer attention to the exact behavior but this one is a good sound so really doesn't matter.
Jeffers0n
150
138
Bay Area
I hear the exact sound that you have in the video. My first car was at the same speed (around 35 MPH) and my second car is around 65 mph. Makes like a high pitched beeping sound.
Toke_Holledig
38
10
Denmark
Hey
Did you find a fix?
I have the same issue.
Use max volume:
Oldschool496
704
396
Florida
I think it's completely normal.
I second that, totally normal, as Model S drivers out here have a small list of noises that take a long time to digest. AC is one of the most noticeable, especially on hot days at stops. Wind, Motor Gear Drive front motor(which I actually love that sound), no other prominent noises.
The things that really amaze me though, very little other noises that for such a quiet car, creaks and rattles do not exist. Thats a testament to how well they are all built. Any other American car rattles and creaks like crazy. In an electric car you would notice this in seconds and it might drive you crazy. You for sure might think twice about buying it also.
Toke_Holledig
38
10
Denmark
Thanks for writing. I really want want to believe you - I do. But I just can't understand, why some model 3 owners don't have that bip/whistle noise?
please listen to this clip with max volume. mic. is pretty bad.
Thanks
