I decided to replace one of my front wheel bearing hubs after listening to a rumble in left turns for several months (an especially severe pothole impact). I have a car lift in my home workshop, so it made sense to indulge my curiosity and do it myself. What I'm glad to report is service on these cars is very well thought out. First, the parts from Tesla were less expensive than I'm used to paying for questionable aftermarket parts on my other cars, and much less than dealer sourced parts for typical cars. So Tesla is clearly not trying to gouge us with parts costs. But the cheap parts are a minor part of the good news.
Everything in the front suspension was so well thought out for easy serviceability. Everything was reachable without major contortion, including the bolts on the back side of the steering knuckle that were holding the hub on. It's a big deal, because on a lot of cars half shafts and control arm bolts have to come off to reach hub bolts, making it much harder to put things back together under spring tension at the end. It's basically like the service personnel were valued members of the team, advising the engineers through the design.
I realize it won't be a big deal for most of you until warranties are up, but it should bode well for long-term servicing costs if the jobs are made as easy as possible. Honestly, it made me want to take a Tesla engineer to dinner.
There are obviously some things about Tesla that aren't perfect, but I'm a happy customer tonight.
2019 AWD Model 3. For future reference, the tools needed are:
32mm socket for the axle bolt, with a breaker bar or impact wrench to get it loose
21mm socket for the nuts holding the wheel on
10mm socket for the brake rotor retention bolt and a clip securing the brake line to the steering knuckle
e18 socket for the bolts holding the brake caliper to the steering knuckle
18mm socket for the 3 bolts securing the bearing hub to the steering knuckle
hub or pulley puller to push the half shaft out of the hub as you are pulling it off.
Parts: bearing hub, 32mm axle bolt (one time use, tightened to 245 nm), anti seize paste for the splines on the axle. Total cost: $126.
