AWD: is the rear motor the same as in the RWD?
SoCalGuy
1,416
1,095
So Cal & New York, NY
Just wondering if the rear motor in the AWD M3 is the same as the one in the RWD version (i.e. are they just adding another smaller motor up front or are they replacing one large rear motor with two smaller ones)?
I don't think I've seen Elon or Tesla officially comment on this...
marusan
108
80
Silicon Valley, CA
Elon Musk on Twitter
General wisdom is that means the same motor in the rear. AWD and AWD-P both get the same motor in the front (AC induction), but the performance model rear motors are selected from the best of the motors produced, and they unlock extra performance through software. Very different from the PxD Model S/X, which receive larger motors. These are the same motors they're putting on all the M3 rear axles.
Reactions: FarmerDave
mongo
12,865
37,840
Michigan
It's the inverter that's getting 'binned' not the motor...
Given the integrated design, it's hard to have one without the other...
They would need to temp clamp the output leads to a motor simulator/ dummy load, bypass the cooling, and then retest after mating. Which isn't to say they couldn't test the electronics separately and I'm sure they do before assembly at low power, but for long duration drive unit high power testing, it is simpler and more accurate to use the complete assembly.
Reactions: Zoomit
Daniel in SD
6,281
8,933
San Diego
The P probably doesn't even produce any significant extra power from the rear motor. Only need 50% more power to go from 0-60 in 3.5s vs 5.1s. That could be accomplished with a front motor that has half the power of the LR.
PhaseWhite
856
2,316
Minneapolis,MN
The math checks out: The rear motor doesn't have to make any more power than LR3 to hit 3.5s
0-60 mph Calculator for Cars | Calculate Estimated 0-60 Times
380KW & 4000LB & Dual Clutch = 3.5s
Though I think there's a good chance we'll see some sort of speed mode like Ludicrous that boosts power output, likely to levels that the new 100D motors put out: ~425KW. That will bring 0-60 down to 3.25s. We might have to wait for some Model S / X speed boosts first though as I have to imagine the new pricing on the Performance 3 is going to put a damper on Model S sales already.
mongo
12,865
37,840
Michigan
Elon’s tweet also mentioned "silicon carbide inverters", so I don't think so.
I think that tweet meant all the 3 inverters are SiC. Otherwise, you would have some AWD/RWD with non P level SiC (didn't make the cut when binned) and some with non-SiC.
To @SoCalGuy 's point. If the yeild on the drive units is high enough to have surplus, then there would be AWD cars that are P capable (assuming both motors are high performers). If Tesla keeps them paired and traced, AWD could get the underline added (although I may have read that there is a rear forelonk change also, but that's no biggie)
Came across this article that includes tear down photos of the rotor and stator from Munro. Hadn't seen those before.
Tesla Model 3 Powertrain Fun. From Carburetors To Carborundum. You've Come A Long Way, Baby! | CleanTechnica
Reactions: J1mbo
mongo
12,865
37,840
Michigan
I've got my mind on my motors
And my motors on my mind...
-snoop Tesla
Recent tweet from E.M. :
Twitter
ℬête Noire
3,105
2,556
TX
Model S and X are induction. Model 3 is PM.
Not if they are front motors for the M 3, then they are induction.
He wasn't clear why he posted it, just a goofy Dune reference about spice flowing. So I don't know if they are supposed to be front motors for AWD or they're Performance binned motors.
However from the shape, those may be the fronts. Compare to the shape in the configurator, the part where the axe runs through is sort of separate from the motor assembly and well past that the forward frame mount.
