Well I have owned a 700whp WRX, a Lexus IS-F and 2005 Mitsubishi EVO. I tracked my car Road Atlanta and Atlanta Motorsport Park.
What you say about acceleration makes sense but that's not what I am trying to say. The Model 3 Performance accelerates quicker therefore it is faster and needs better stopping power than the base versions. It is being sold as a performance car....
Your original remark was a quicker car needs better brakes "for safety"
Which simply isn't true.
How fast the car is is utterly irrelevant to normal street braking.
Track-specific needs can be impacted by braking systems certainly- but that's not a car safety feature- that's a track performance feature.
You keep saying that tires is the only factor on braking time and that's not entirely true.
Braking distance, not time.
And it is true, if the rest of the car is working correctly.
Remember what happen to the Model 3 and Consumer Reports? didn't they improve breaking distance by 10ft by changing the ABS modulation. I don't think they changed the tires... right?
Right- their software had a bad algorithm so the ABS wasn't working properly under some conditions.
That has nothing to do with physically bigger brakes though- which is what you're asking for.
Take a bone stock factory car with properly working brakes, put a $10,000 big brake upgrade on it, change nothing else.
Now take it up to highway speed and slam on the brakes.
The upgraded car will stop in
exactly the same distance it did with the stock brakes (possibly worse if the BBK isn't well designed and confuses the ABS computer).
It won't ever stop shorter, because physics tells us that's impossible.
(see also Porsche- where you can
literally buy a $10,000 brake upgrade that doesn't reduce stopping distance in normal street use.)
There is no way of knowing that the current brakes are the best they can be.
Sure there is.
Does it engage ABS?
If yes, then MOAR BRAKES does
literally nothing for you in normal use.
again- that's how physics actually works.
The brakes don't stop the car, the tires do.
Here is some way on improving stopping power other than changing tires.
Engineering Explained: Brake Systems And How To Improve Stopping Performance
[/QUOTE]
I watched your video. The guy doing it makes the same point I did.
Stock brakes can already lock the wheels, "more force" doesn't help when that's true.
He does talk about how in some conditions changing brake parts can impact the
wear on the system... and can impact the
feel of the system. That's certainly true.
What it can't do is ever make you stop any shorter than the stock brakes did the first time.
I strongly suggest this article for folks to understand what each part of the brake system actually does, and does
not do, and why the
only way to reliably reduce braking distance is better tires.
GRM Pulp Friction
The author has designed brake systems for major OEMs and aftermarket companies, teaches SAE master classes on brake system design, and has literally written books on brake engineering.
tl;dr-
In normal street use bigger brakes literally don't you stop any shorter at all. They physically can't.
In track use/abuse bigger brakes (if designed right) can reduce fade resistance, customize brake feel, change wear characteristics....all potentially important things... but they still won't enable to car to ever stop shorter than the stock brakes could on the first stop. You'd need better tires for that.
