Awesome iOS App called Stats
Steve_T
25
19
Massachusetts
My wife keep telling me that I need to write an Android version too. Writing an Android version means a complete re-write on a platform which is not fun to develop apps for.
Take a look at Xamarin/Visual Studio for Mac. I've been developing with it for a long time now and find it very useful if you have a lot of code that can be shared. UI is a little different depending on how custom your objects are but if you're going to rewrite it, using C# is pretty easy.
Reactions: f8K37Sq31
f8K37Sq31
Former Vendor
Jan 1, 2017
398
450
california
Thanks! I was planning to look into Xamarin. The app has a lot of custom UI.
f8K37Sq31
Former Vendor
Jan 1, 2017
398
450
california
Question - After setting up a few Siri shortcuts and modifying the command words, is there a way to go back and check which shortcuts were activated and what command words were used?
Yes, please launch the Settings app and tap on "Siri & Search" / "My Shortcuts"
iOS doesn't allow the app to access phrases that the user has assigned.
f8K37Sq31
Former Vendor
Jan 1, 2017
398
450
california
Just released an update which adds Siri Shortcuts for enabling/disabling Sentry mode. See attached.
Thomas Edison
1,513
2,119
Portland-ish
Feature idea, not sure if this is doable: connecting the price of gas per gallon to some online registery for the national or state average? So we wouldn’t have to adjust it over time.
Got the app last week and love it btw. Great work!
bpjod
424
1,792
Alberta, Canada
Is there a quick way to turn Stats off if I need maximum battery conservation? For instance, if I'm leaving my car in an airport parking lot for a couple weeks in the middle of a cold snap during a Canadian winter (think daily highs below -20C for a couple weeks), I really don't want scheduled heating/cooling coming on every day. I also don't want to delete all my programmed scheduled events because every day of the week I work a different schedule and I don't want to have to set them all up again on my return.
Basically I'm looking for a vacation mode that stops all Stats access to the car until I turn off the vacation mode. Make it a big slider at the top or bottom of the settings menu for easy access.
f8K37Sq31
Former Vendor
Jan 1, 2017
398
450
california
I'm planning to add an enable/disable switch to each of the climate schedules, but in the meantime if you really want to keep those schedules, you can modify the schedules by turning on the switch shown in the attached screenshot. When you do this, at least for the first day please check to make sure that the climate does not turn on according to the schedule; I don't want your car to run out of battery at the airport
f8K37Sq31
Former Vendor
Jan 1, 2017
398
450
california
It's probably not worth the trouble. I need to be able to get the price of gas for all over the world and answer questions like "my favorite gas station sells gas for cheaper", etc.
Reactions: Thomas Edison
bpjod
424
1,792
Alberta, Canada
How about using the average price per state/province? Here is a source, I'm sure there are others. Not sure about what it would take to get the rights to use the data, simply a suggestion.
bpjod
424
1,792
Alberta, Canada
Good suggestion. I still like a vacation mode switch so I can shut off any and all features of the app that might contribute to possible battery drain, no matter how small, with the flick of one switch. No worrying that I forgot to disable one schedule or the like.
diamond.g
2,396
1,350
Moyock, NC
How do I swap cars? My first 3 was totaled and I got a replacement today but I can’t seem to figure out how to select it in the stats app.
CCIE
363
655
CT
Kill the app and disable background app refresh for it and the Tesla app. That should keep it from doing anything. Make sure you do so on all devices where it's installed.
f8K37Sq31
Former Vendor
Jan 1, 2017
398
450
california
Never mind the new car shows up up top. Pretty slick.
Sorry about the car being totaled and I hope you are ok. It's good that you got a replacement.
You can ask Tesla to remove the old car from the account. The app automatically lists cars that are linked to your account and if there are more than one car, you'll see a button with the name of the car. Tapping on the button switches between cars that are linked to your account.
Snowstorm
1,488
1,407
Ontario Canada
What’s with the washed out low contrast colours? Can we have an option where the background is black instead of gray? Would love a darker, higher contrast screens especially for those with OLED screens.
