Backing Out
Discussion in 'Model S' started by Cmor off, Jan 4, 2017.
Tags:
  1. Cmor off
    Cmor off New Member
    Long Island NY
    My new Midel S 60 D did something strange today. I was parked between two cars. When I tried to back up the car stopped. I tried several more times and each time the sensor recognized the car next to me it stopped. After 5 or 6 tries I finally got it out of the spot by moving back a foot and stopping then a foot more and stopping etc. once clear of the car next to me I could back out. Any one have similar experiences or suggestions please. Thanks.
  2. Ko Olina
    Ko Olina Member
    My 90 D did a similar thing at the Rocklin CA service center last month. I tried to back into a SC stall it it just would not let me back up. I had to move forward and find another stall. There was nothing in the rear but there was a truck in front and off to the left but that should not have impacted my ability to back up.
  3. Tam
    Tam Active Member
    Visalia, CA
    Did you buckle your seat belt on when you put on your reverse gear?
  4. drklain
    drklain Member
    Scottsdale, AZ/Fairfax, VA/Brussels, BE
    Not saying this is what happened in your case, but there are reports that some drivers have their car stop while backing because they turn to look back and lift enough weight off the seat to have the car think there is no one in the seat and it stops....
  5. kort677
    kort677 Banned
    florida.
    best answer, that is probably what the OP did
  6. Nosken
    Nosken Member
    Lincoln, CA
    Maybe summon would have helped.
  7. andrewket
    andrewket Well-Known Member
    More than likely this is what happened. There is no feature/capability in the S/X that I'm aware of that would force the car to stop while in reverse. If it put the car into Park, this is what happened.
