Backseat seatbelts plugs
akng126
164
12
Laguna Beach, CA
Took off my backseat today to fix the squeaky noise and I just noticed there are 3 white unplugged plugs going to the seatbelts buckles but no cable is attached to the seat to connect to those plugs when I take it off. Is this normal or is there something missing ?
akng126
164
12
Laguna Beach, CA
I don't think these are the rear seat heaters plugs because each of them is wired to the 3 buckles. I think they're sensors but there are no plugs attached to the seat I took out that can be connected to the 3 plugs attached to the metal frame
Mar 1, 2018
119
142
San Marcos, CA
In the European market, there is an occupancy sensor under each of the 3 sections of the rear seat cushion, same as on the driver's seat. These are used to activate the seatbelt warning if someone is sitting in a rear seat with the seat belt unbuckled.
akng126
164
12
Laguna Beach, CA
Third seat belts
That's what I figure too but there's no wires connected to the cushion once I pull it off the metal frame. In my wife's model 3, there are these sensors. I'm just trying to figure out if the wires are missing from my car or that my car doesn't come with this feature
Mar 1, 2018
119
142
San Marcos, CA
I'm just trying to figure out if the wires are missing from my car or that my car doesn't come with this feature.
It just didn't come with that feature.
Carmakers often use the same harnesses in cars with different options to reduce the number of wiring harness variants required at the factory and later in service. In fact, the early Model S had only one 12V harness variant; every car sold had the same harness regardless of options. I think they finally broke it out into Tech Package and non-Tech Package harnesses sometime in 2013.
paul.scott
27
12
Las Vegas, NV
Those are indeed for pressure sensors for rear seat seat belt notification. I have heard they became standard in American Model S in October of 2016.Below is what the pressure sensor itself that attaches to the seat bottom looks like.
