Backup mode for rearview mirrors
Discussion in 'Model S: Interior & Exterior' started by drock3800, Aug 18, 2017.
  1. drock3800
    drock3800 Member
    Yorba Linda, CA
    Hi all,
    Just took delivery of my car on 8/3 and noticed that in reverse with the option selected, the rear view mirrors do angle slightly down, but not nearly enough to follow the lane lines. Is there a way to adjust the reverse mode for the mirrors or is the position they take hard coded/fixed?
    Thanks,
    David
    Blue Model S
  2. araxara
    araxara S-P85#3,218 X-90D#3,299
    Tucson, AZ
    The reverse mirror position is settable: Put your car in reverse and adjust the mirrors accordingly - then save your your settings under your profile. The next time you go into reverse, the mirror will go where you had saved it last. There is also a Controls Setting to enable this feature, but I think it's already enabled for your car because your mirrors already go down when in reverse.
  3. drock3800
    drock3800 Member
    Yorba Linda, CA
    thanks Araxara. I did adjust it but didn't save it in that mode. I'll give it a try.
