Bad replacement wiper blades
Discussion in 'Model S: Interior & Exterior' started by zdre, Oct 23, 2014.
  1. zdre
    zdre 40kWh Model S, Model 3LR
    St. Louis
    I have had my wiper blades replaced in the first yearly service, and found that the new blades were leaving a wide streak in the middle of driver's side blade. I asked the service center, and they replaced blades with another set, but the problem remained. It seems that the new long blade doesn't curve enough to provide even pressure, and the middle of the blade actually gets too much pressure. The new wipers also click louder when reversing direction.
  2. shelbri
    shelbri Member
    Sandy Hook, CT
    I've had the same issue since receiving the car in mid Sept of this year. I found that wiping the blade with a little soap and water temporarily fixed the issue. Not impressed with the blades though.
  3. yobigd20
    yobigd20 Well-Known Member
    Skaneateles, NY
    A good water repellant coating on your windshield you won't even need to use your wiper blades, even in very heavy rain.
  4. Chipper
    Chipper Active Member
    Chattanooga, TN
    Others have commented that adding a repellent coating to the windshield actually causes wiper problems.
  5. pgiralt
    pgiralt Supporting Member
    Cary, NC
    I'm having the exact same problem. The service center replaced the blade and after that didn't fix it, they replaced the whole arm. That still didn't fix it when I got the car back so I took it back and they did something with the angle of the blade that seems to have improved it a bit, but now it seems like it's doing it again a week later. I've also noticed that during heavier rain, the bottom of the driver side blade skips instead of gliding smoothly.
    All this started after my annual service in August. I wonder if they changed to a new supplier of wiper blades.
    I've been thinking of just going out and buying some higher quality aftermarket blades to see if that helps.
  6. Kbsilver
    Kbsilver Member
    Central NJ
    In my experience this is usually caused by contamination/dirt on the windshield. Trying cleaning both the windshield and the wiper blade real well and see if this stops the chattering/skipping.
  7. jerry33
    Texas
    Depends on the coating. I've had no problems with the Chemical Guys window cleaner (which contrary to popular belief appears to work just like the coatings). No problem with the replacement wipers either.
  8. pgiralt
    Cary, NC
    This was with a brand new wiper blade (had just taken the car in for 1 year service) and the car was clean (again because they cleaned it at the 1 year service).
  9. Kbsilver
    Kbsilver Member
    Central NJ
    If caused by deposits on the glass, a regular washing of the car will not remove them. It takes some force/effort to get the glass clean. I've used solvents to get it off (tar remover). If you rub the dry glass with a paper towel or microfiber cloth, you can usually feel it.
  10. pgiralt
    Cary, NC
    I'll certainly give it a shot, but it's unusual that the same problem happened to me and the OP after the 1 year service.
  11. Zextraterrestrial
    Humboldt/Los Altos
    I have the same problem with brand new drivers side blade.
    It wipes ok going upwards but the down stoke leaves a blur streak, have pulled over to clean off the blade quite a few times but it does nothing
    + the wiper sensitivity just plain sucks for water, what is it trying to measure?
  12. stev
    stev Member
    Brugge, Belgium
    Unbelievable - also this same problem : upstroke is fine, downstroke kills the view. Driver's side only.
  13. AmpedRealtor
    AmpedRealtor Well-Known Member
    Phoenix, AZ
    I had annual service done about a month ago. I'm assuming they replaced my wiper blade, but I experience none of these issues. The windshield is streak free. The wiper does pull a smattering of water back onto the driver's side on the downstroke, since water pools up on the left side which is then pulled back onto the windshield a little bit on the downstroke. But no streak.
  14. bhuwan
    bhuwan Active Member
    Boston, MA
    Same issue. I've had this issue since day one. Reality is tesla wipers suck
  15. iadbound
    iadbound Member
    No. VA
    I had the same issues when the car was delivered on 9/24. New wiper blade has largely solved the problem.
  16. shelbri
    shelbri Member
    Sandy Hook, CT
  17. pgiralt
    Cary, NC
    Did you get new aftermarket blades or did you let Tesla replace with new blades?
  18. lloyds
    lloyds Active Member
    Bay Area
    I had service change the blade out as the driver's side kept skipping. Now it's much better.
  19. iadbound
    iadbound Member
    No. VA
    The Service Center put a new blade on. So I assume it's OEM.
  20. William13
    William13 Active Member
    South Bend
    I have given up on the OEM. ICON blades rule.
