How much do you think batteries can store in 5 years, and how cheap will they be?
Will there be a P400?
Increasing battery capacity also increases charging times. Even if you could produce a 400 KWh battery pack - how long would it take to charge it at a typical home?
Absolutely.... And, to some degree, it shortens charging time. If you drive 200 miles on a 300 mile pack and need 200 miles to get to your next stop, since the "full" mark is 300 miles you get to take advantage of the fastest charging speeds during the entire time you're adding the miles you need. If you have a 230 mile pack and need 200 miles to get to your next destination you have to wait through the much slower charge rates as the battery gets more full.No, it doesn’t. It would actually decrease charging times. You’re falling into this logical fallacy, where you’re thinking of the battery as being a binary object, where it’s used, and that makes it “empty”, and then you fill it, and that makes it “full”. But it’s not like that. You drive some amount of miles, and you need to refill that amount of miles, unrelated to what the total size of the battery pack is.
Think this through. You drive to work and back home and are going to refill overnight. You used 88 miles or something that day. So you only need to refill 88 miles, not however big the battery capacity is. People get this wrong idea that bigger and bigger batteries in the future are going to mean more and more charging time, but that’s not so. You only live however far you live from work. An 85 kWh or an 85,000 kWh battery does not change how many miles you drive and need to replenish.
So back to the other thing I said—actually faster charging time is because with bigger batteries, you get to charge faster for longer periods of time. Remember what I was saying about miles driven and miles to be recharged? When you’re on a trip, and you go 200 miles at a time between Superchargers, then if you have a battery where 200 miles is all of it, then you’re in the tapering slowdown for a lot. But if 200 miles is only half the capacity, then you get to run at the fast full speed charging rate the whole time, and you’ve got your 200 miles back sooner.
