Battery 101: 40 000 cycles with Panasonic 18650 cells?
slyastro
Electrical Engineer, Frank Boucher, just wrote an interesting and easy to understand technical article about Panasonic NCR18650B Cells.
He also explains why a EV battery pack will be good for much more than 500 cycles, but up to 40 000 cycles (by keeping the pack between 30% and 70% SOC).
That means that with a 85 kWh Model S, you could drive 100 miles per day per cycle and drive 4 000 000 MILES!!
I think we should keep it for reference for all those EV sceptics that think that the battery will be due for replacement after 2 years!
Ok, he kept it simple for the «mass» non technical reader. Your input about batteries physical characteristics would be appreciated.
LET'S TALK ABOUT THE PANASONIC NCR18650B
nwdiver
7,432
9,441
United States
The thing that makes this a bit more complicated is the 'balancing' issue. I have little doubt that shallow cycling the battery between ~30-70% increases longevity but it also decreases usable capacity since the cells become more unbalanced if you don't do a full range charge. My max range charge is down to ~226 miles but I claw about 10 miles back on road trips due to frequent >90% charges.
omgwtfbyobbq
1,450
1,612
Southern California
I don't see a link either, but it's probably from this SAFT chart or something similar.
It's probably accurate assuming the batteries are always at ~75F and are charged/discharged non-stop, but IRL, there will be losses in capacity due to aging that also reduce capacity. The lifespan of most packs will probably be pretty good, but probably not 40000 cycles at 40% dod good.
mguw
14
3
FR
Why shouldn't it balance? On my rc helicopter batteries I can charge to 50% with balancing. It is what we call storage mode.
jdbob
98
20
John Day, OR, USA
I don't think it needs to charge fully to balance the cells. This isn't for a Tesla but a PHEV but I'm guessing the method of balancing is the same:
"Individual cells can deviate over the life of the high voltage battery. The purpose of cell balancing is to equalize theindividual cell charges. By balancing the cells the high voltage battery maintains top efficiency. The BECMcontinuously monitors individual battery cell voltages and will perform balancing automatically only when required.When balancing is performed BECM discharges individual cells with the highest voltage to match the remainingcells."
I don't see any reason why the battery control module in the Tesla couldn't discharge individual cells, no matter the state of charge of the entire pack.
scottf200
3,770
3,326
Chicagoland ModelX S603
The link is there on my original post in blue, no?
Here it is again: Let’s talk about the Panasonic NCR18650B | EV And More
I did appreciate the article overall. Thanks.
This is an extremely misleading statement. I think with the Tesla pack this occurs regularly in cold weather and I've read it in many threads. HOWEVER, I've never read that happening to normal Volt users ... even those that park outside. May happen in GM extreme testing. I have a 2011 Volt that I've left outside in the open parking lot for 9-10 hr workday in some of Chicago's coldest day and the regen felt the same as on warm days.
Temperature effect: an important note: At temperatures below 10 Celsius, charge at a 0,25C rate. This indicates that when it’s cold, the battery must be recharged at half the current. In a Tesla Model S with a cold battery pack, regenerative braking is limited or even unavailable. Gradually, as the pack warms, recharging via regenerative braking becomes available again. The Chevrolet Volt does the same when its battery is cold (as when left unplugged overnight in extreme cold).
Early Volts are also from 22% to 87%.
GM limits the cycle from 17% to 80% of energy storage levels for the Volt.
Johann Koeber
1,176
3,379
Hersbruck, Germany
Very interesting information.
Also keep in mind that recuperation does charge the battery - somewhat. This happens all the time. I think the way I drive it gets a little charge about every minute or so. LOTS of cycling the battery. But each charge is just very small, usually less than 1 %, even 0.2 %.
So now I feel sure, these frequent but small charges will not hurt the battery in any significant way.
On another note: My Lexus 450h GS hybrid car has gone 200,000 miles without any noticable battery degradation. The battery is a completely different tech (I think NiCd), but seems the same reason it does not degrade.
Ampster
1,636
414
Sonoma, California
It is a function of the settings on the balancing controller. Various RC chargers have different balancing settings. One of my RC chargers will pull down the highest cell even when there is no charge voltage. RC chargers have more settings than we get when charging a Tesla. The battery management system on one of my conversions lets me pick the voltage when I want the balancing to start. There is a body of thought that the Tesla charging/balancing process only balances at higher levels of SOC.
ratsbew
1,157
841
O'Fallon, IL
This is interesting, but going between 10 and 90% will (should) still net you 200,000+ miles of endurance while retaining sufficient capacity. I'd rather plan out how long I intend the vehicle to last and not artificially limit myself so it lasts a theoretical 4,000,000 miles.
Lex
805
318
Toronto, Canada
True that, but it's not a bad thing to do the right thing as often as possible especially if it's not a big deal. But I agree, I use the car like Tesla designed and so far so good (ahem, well, full disclosure my MS's pack is getting brain surgery in the Mothership right now).
As for battery management I actually had hoped some of the Tesla secret was keeping individual cells between this range (I previously heard 40-60 but 30-70 is a nicer) and/or resting certain cells... but that is just wasted mass this early, I guess.
AZ Desert Driver
Rare combination
Mar 12, 2016
1,335
715
Tucson AZ
I'm not an electrical engineer, so forgive my neophyte question.
1) Batteries should not drain below a floor of 20% - Seems like that could be defined as zero, and the 0-20% as "reserve" and take this question out of the drivers worry factor. That seems like an easy program for the brains at Tesla. Dumb-or smart?
2) Batteries charge fast, then slow down when near full....To optimize supercharger time, could one fill a capacitor and let that continue to top- fill the battery while disconnected? Would incorporating this type of device help in the life of the battery cycling? Dumb-or smart?
Reactions: jbcarioca
FlasherZ
Sig Model S + Sig Model X + Model 3 Resv
Jun 21, 2012
7,024
1,013
Just for reference, the article makes an assertion that the car uses NCR18650B cells. I don't believe that's ever been confirmed anywhere, and that they are cells made specifically for Tesla in the 18650 format with proprietary formulations.
I may be wrong - so corrections welcomed if you have an authoritative source.
It doesn't necessarily invalidate everything else in the article, but extrapolations based on the 18650B data sheets may not be correct. I personally believe that the Tesla packs should outlive even the 18650B standards, so it may be better in the end.
Reactions: Panu and jbcarioca
jbcarioca
5,068
22,899
To be consistent we need to know what vintage the cells were since Tesla has had modifications in chemistry, the BMS, charging protocols and many other factors since the first Roadster until today. Anode design also changed quite significantly with the advent of 70-90 kWh packs. Just knowing a given cell was produced by Panasonic, that all have been 18650 format really tells little about longevity. Even bench tests are at best part of the story because the operative measurements need to be installed in an operating environment.
Looking at the actual observations collected on EV battery lives it is safe to say all of them from every car builder, seem good to have longevity equal to or better than ice with less maintenance and equivalent power degradation.
More than that is really speculation, isn't it? No matter how many individual cells may be tested...
Lex
805
318
Toronto, Canada
I'm a nerd, so let me try :p
Yes, Tesla's programming prevents you from damaging the pack. Car shuts down hardcore before that, you may even need a boost just to tow.
But if you didn't charge as quickly as possible, perhaps permanent damage would start in .... x(x?) hours.
Hmm, well let's see, capacitors are really just short-term energy storage "cells" that are good at buffering power so perhaps they could play a part in disconnected Supercharging one day, quickly pulling-in energy and then feeding it back out as quickly as possible either for propulsion or more charging....
They do like to explode when they get old though :p And once they're depleted they would be dead weight. But I've typically been surprised to see how many capacitors find their way into circuits, and I have a feeling they're already there, for Supercharging possibly not in the car but in the SC charging stack.
