Battery calibration does help!!!! (At least for my car)
adrieng1977
9
24
Chicago
Hi
I just wanted to start this thread because I have seen many posts now that says that the BMS does a great job and that battery calibration does not help.
Well both statements are true and false.
Long story short, (see The usual Battery Degradation Topic), i kept charging my car to 90% every night like it was recommended by tesla but my max battery @100% kept dropping up to 264miles @100% from 310 estimated with close to 30k miles. I was worried it would keep going down but Tesla Service would tell me its normal, and that there is nothing that can be done.
After doing a bit more research, some people did recommend to :
For a couple battery cycles do:
1. let the car go to deep sleep (no sentry mode on, and no third party app(that one not true cuz i still use teslamate)) at different battery level all the way to 10/20%
2. charge to 100%
3 rinse wash and repeat a couple time.
Well after 3 charges to 100% i can tell that the BMS has done its job and re-estimated my battery level from 264 to 282miles @100%.
I think it all depends on your driving habits and how you charge.
We do not drive a lot lately. So we would charge to 90% drive a bit, and charge back at night like recommended by tesla.
I assume that the problem is that the BMS would always check the battery at the same levels so it would not be able to do a proper estimation.
Doing the "calibration" has allowed the BMS to do its job and re-estimate properly the battery.
here are some charts to prove it.
Anyways, this is my experience. It might not necessarily work for you, but its worth a try.
Good luck.
Adrien
Randy Spencer
Supercharger Hunter
Mar 31, 2016
3,745
3,922
Alameda, CA
Yikes 282 miles after only 30K miles? I am just at 100K and my 100% is 299 down from the 310 original in Mar. 2018
I read your thread because I hoped to get closer to the supposed 325 that I may or may not have ever gotten after that software update for our original RWD LR cars.
ichorus
45
13
Glasgow
Hi
2. charge to 100%
Good luck.
Adrien
Similar experience for me. 282 miles P3D I’m at 40k miles. I’ve kept it in percentage to take my mind off it, but now the app tells me both, so is on my mind again recently.
mattnis
87
75
Chicago
Mine is at 280 (from 310) after only 19k miles.
