Battery capacity increasing
Gjawhar
12
North Carolina
Ever since I took delivery back in August, my capacity was in the low 250s (miles) right off the bat. I switched my capacity reading to percent just so I wouldn’t obsess over it. I have noticed that capacity is not declining but actually ticked up a mile or two. Graph attached. Does anyone have a similar experience?
kavyboy
1,173
1,970
Spring, TX
The number is an estimate, so it will move around a little bit as conditions and measurement factors vary. (Note that rated miles has nothing to do with how you drive.) My 90% was 216 miles when new, and it's 220 now. It's big changes in a short period of time that may signal a problem.
Reactions: Rocky_H and SSedan
MS_Dream
73
54
Zephyrhills, Fl
This probably means that your lifetime watt hours per mile (whm) is below average. Estimated range is capacity/whm so if your whm decreases over time then your estimated range increases. Lots of factors affect whm so your estimated range might fluctuate.
  • Disagree
Reactions: Rocky_H and ucmndd
ucmndd
6,238
11,652
NO.
Wrong wrong wrong.
Rated range is estimated battery capacity divided by a constant. It is in no way affected by driving style.
BerTX
3,505
3,559
Texas/Washington
NO.
Wrong wrong wrong.
Technically, the statement was that estimated range takes driving habits into account, which is true. If by "estimated" they meant "Rated", then you are right in correcting that misconception. You can't really blame people for having this wrong information -- ask at any Service Center and they will tell you exactly that.
