Hi Christopher,
With all due respect you haven't answered Evan's question.
Assuming for the sake of discussion the car is being monitored at essentially the same temperature, how does one differentiate between true permanent loss of capacity versus a temporary loss due to being out of balance?
If someone has done a basic Maximum Range charge as you have described and the car is driven as soon as Maximum Range is achieved will that bring the car into balance? Or in your opinion do you need multiple Maximum Range charges? If so, how many? Does the car have to sit at high voltage for a certain duration to assure balancing? If so, how long? Can you provide any definitive guidelines to assure the battery pack is balanced?
Thanks.
Larry
I'm sorry I did not properly answer the question. To determine real degradation/permanent loss, as compared to being out of balance, yes, multiple range charges are needed.
Driving right after completion should not cause any issue with balancing with Lithium batteries. Cutting the charge short. As example, anyone here that has seen the charge time remaining continue to say "one minute remaining" continue for 20 minutes, or even a hour, cutting that short will stop the balancing process. The more out of balance your pack is, the longer that will take.
It can and usually will take multiple range charges to balance the pack, the worse the pack is out of balance, the more times and/or longer it will take each time to complete that range charge. It goes relatively quick for me now, usually 10-15 minutes on 1 minute remaining, as I regularly range charge.
Now, I know this is long winded post, however, somewhat needed to get to my point (I like to provide as much information as possible). Given the same temps, both during charging (garage etc...) and outdoors, after 2-4 range charges, you should see a gain in completed 100% range charge's rated range. You will need to compare that with the original delivery range. Now, to get the most accurate reading compared to original range, try to compare range at the same temps it was when you first got your vehicle, if that is not possible (cant remember the temp), approx 75*F-80*F is a good baseline (in my opinion).
Now, if somehow we could get access to the battery management console built in behind the password protected screen on the car, we wouldn't even need any guessing at degradation, as the cars computer fully calculates the complete % of losses. I will put together something to demonstrait what I'm talking about with this using my laptop's now very degraded battery.
Basically, the cars computer does it this way: What % we are able to charge to, is the % of what capacity we have. So, as a example, say the pack lost 10% of it's capacity, so now the pack is 90% capacity. When we charge the car, and select to charge it to 100% capacity, we are only able to charge it to 100% of the CURRENT capacity, not original. So we charge to 100% of 90%. The car automatically adjusts for this. The iPhone does the same. I have a jailbrake program that can actually show the degradation of the iPhone's battery.
I hope that wasn't too confusing. I will do a video demonstration on the degradation of my iPhone battery and my laptop battery this weekend. It will be easier then taking a dozen pictures and trying to explain.
Anyone up for doing a YouTube live Q&A? or a Google Live Hangout? I'm up for it and can host.
- - - Updated - - -
What Christopher says is true. My 10 month old 85kwh car with 13.1k miles just range charged to 263 rated miles in 27* F weather.
I'm not as familiar with the 85kW pack (as obviously I do not have one to play with
) what was your original factory rated range?
Oh, and for the record, temps do not matter much if doing a charge on the Supercharger, especially for balancing, unless you start charge on a cold battery at 50% or higher battery power remaining.
The heat generated by the initial high burst of power (for the 60's it is 105kW for the 85's it's 120kW) is enough heat to get your pack up to 100% operating range in a short time. If your pack is cold (limiter of regen still in place would quality) the Supercharger will charge at a much reduced range, and may not generate enough heat to get it to full operating temps.
I actually found the balancing when using a supercharger took quite a bit longer, but, the final result was a much better balanced pack then when on my 14-50.
- - - Updated - - -
No offense, but I had to give up on the video. After 5 minutes all I'd learned was the ideal charge was between 30 and 80% and not to charge to 100% and let it sit. I'm not sure if the facts and tips started flying later in the video, but another 15 minutes is quite a bit.
Sorry. I try, that's all I can say. I try to start off as simple as possible. Many people that watch my videos have never even been in a electric car, or are just being introduced to the technology. I start simple, and work up to the more complicated. Battery care and maintenance is not something that can be covered in a 5 minute video. In fact, I could have made it longer, much longer.
I have actually written a book on electric cars and converting your vehicle to electric. Long time ago though, not as much applies to the modern EV's. I could write another with whats spinning in my head right now, but alas, I do not have the patients
No offense taken
