I believe the charge normally stops right at the set percentage. However, after the charge the BMS might adjust its readings and show a percentage that'S a couple points higher or lower after a while. I have that often on mine. When I get in the car the next morning, it's sometimes 1-2 percent lower but it's also sometimes 1-3 percent higher than what I set. I believe this is normal.
