Battery charging levels
Moderator note: The first three posts in this thread were moved from a thread on an unrelated topic.
Batteries:
What I have learned over the years about batteries is that, in order to get the longest cycle life from your battery, you should avoid discharging below 50%. Tesla recommends that you not charge to greater than 90% state-of-charge.
Tesla’s charging app implies (recommends) that, on a daily basis, you should charge between 50% to 90% state-of-charge. You should avoid discharging below 40% state-of-charge. Of course, the car is designed to occasionally be discharged over a larger range for longer trips.
I recently took a Photo-voltaic/battery design course and the recommendation was: size your batteries for the design load and then take the number of batteries and multiple by 2 so that you don’t discharge below 50% state-of-charge to preserve the battery cycle life.
Apple recently had a problem with the iPhone Li-ion batteries. They recommend that, if you are not planning on using your iPhone for an extended period of time, you should leave the battery at 50% state-of-charge. This gives you 10% margin to the lower limit of 40%. All batteries self-discharge. When the Tesla is off, the electronics in the car draw a small amount of current adding to the parasitic discharge.
I make an effort to avoid discharging below 50% state-of-charge and have my recharge set to 90%. Shorter stops at the superchargers.
  • Disagree
Reactions: TexasEV and don123
Batteries:
I think you posted to the wrong thread.
Reactions: MelaniainLA
Batteries:
First time I've read about avoiding discharging below 50%. Keeping it around 50%, yes.
If you start charging at 50% state of charge at a Supercharger you are nearly in the taper region where charging will be slower. Staying above 50% during a road trip is the slowest way to travel!
So many of us go down to 5 miles or less kinda blows that away. I see guys driving in on zero miles. The some of us charge to max alot.
I have been in over 20 states, lots of places with no where to charge, so we leave with max caharge. I nearly went to zero in Charleston last year. Finally found a 110v plug. Charging is fun, if you dont worry about it. Also leave it plugged in as per manual.
