Battery conditioning
Discussion in 'Model S' started by skip8jj, Apr 10, 2016.
Tags:
  1. skip8jj
    skip8jj Member
    Portland, OR
    i have looked through the various threads and found a few references to battery conditioning relative to starting in cold weather, i.e. prewarming the battery, but I have not found just how to do it. I have looked in the manual but found no mention. Is this step no longer necessary? Thanks
  2. Petra
    Petra Member
    Palmdale, CA USA
    As far as I'm aware, it's tied to vehicle preconditioning.
  3. skip8jj
    skip8jj Member
    Portland, OR
    Pardon me, but what does that mean? I find no reference to "vehicle preconditioning". Please elaborate.
  4. DMC-Orangeville
    DMC-Orangeville 85D and John Deere 5100E
    NW of the 6ix Canada
    In cold weather you need to warm up the battery. This is done via the app or Visual Tesla. Turn on the heating system in the car. Your vehicle will then begin to warm the battery as well. If you do not do this, in very cold weather, your car will have little or no regenerative braking, and may ave limited acceleration. Most users in cold weather areas plug in their cars, and initiate the warm up while connected to AC power to minimize the effect of the drain on range
  5. skip8jj
    skip8jj Member
    Portland, OR
    Thanks for the explanation. SS
  6. AustinP
    AustinP Member
    Belgium
    Hi,
    Another efficient way is to have the charging completing or almost done at the time you leave with the car. Charging the battery warms it.
    Does indeed require you to estimate the time at which to start charging. Also, when temperatures are very low, you might want to combine prewarming of the car with charging.
  7. DMC-Orangeville
    Also, you should read this blog (from the old site). Doug is in Ottawa, and he has some good hints
    Cold Weather Driving
  8. apacheguy
    apacheguy S Sig #255
    So Cal
    Note that even if preconditioning, the heat target of the BMS is only 8 C. This is not sufficient to completely remove regen limits.
  9. CHG-ON
    CHG-ON Still in love after all these miles
    Santa Cruz Mountains, USA
    There are several threads on this here. Search a bit more and you will find useful info. But essentially, time your charge to end near the time you expect to use the car or preheat the cabin while the car is connected to shore power for at least 30 minutes prior to your departure. You can do this either through Visibletesla or through the Tesla app, oe RemoteS, an excellent app. Quite easy and convenient to do. Visibletesla allows you to program it, as long as you leave the app running on your home computer and your car is set to always connected in the setting menu, which is quite convenient. The Tesla and RemoteS apps requires you to turn it on. The smart preconditioning selection in your car's setting menu has not proven to be reliable as of yet.
