Battery coolant heater failure
Atebit
286
26
PA
On a road trip, car kept aborting charge at Glen Allen VA SC. Then I started getting the navy triangle and "do not drive" message, as well as systems check failure. Roadside pulled logs, said indeed don't drive it. So I ended up in a rental and the car ended up flatbedded back to Raleigh the nest morning.
Diagnosis: failed battery coolant heater. Picking it up later this morning, hopefully no more issues.
Atebit
286
26
PA
This all started Thurs evening. After we got the rental we continued our trip. Flatbed had the car in Raleigh by mid-morning Friday & it was done by Sat morning. It's waiting for me now in the parking lot. So no Sunday service there, but they make up for it by providing over-the-top service the other six days of the week.
GoBlue88
845
251
Carlsbad, CA
So this same failure happened to me on my way to Las Vegas this past Friday. I noticed some strange charging behavior before I left my house in Carlsbad in the morning - I had charged it to 90% the night before and then when I woke up Friday morning I set it to top it off for a range charge which was estimated to take 1 hour and 10 minutes. I left about 1 hour 30 minutes later with a full battery (242 RM - 85 kWh battery) but the car didn't think the charge was done. The center screen kept showing the "estimated time to completion" message with no estimated time. I hadn't seen that before on other range charges, but I had a full battery so I didn't think anything of it.
About 2.5 hours later I pull into the Barstow supercharger with about 52 RM left. There's 2 other cars charging but nobody using 1A so I take 1B. Plug in, things are looking normal. I'm about to walk over to the gas station to get a coke when all hell breaks loose on the dash: first charging winds down to zero, then "check charge cable" warning with red light of death on the charge port ring, then "12 V battery low", then "pull over immediately, car may shut down", (even though I wasn't driving), then "systems check failure", then "car may not drive". I try unplugging and replugging the charge cable - no change. I try rebooting both screens, no change. Car refuses to be put into Drive. Oh boy. Call Tesla roadside assistance, they pull the logs, and their next words are "you need to be towed". ARRRRRGGGGHHH. Here I am at the Barstow supercharger on my way to a weekend in Vegas to meet some buddies and I have a dead car. :crying:
This is where things brighten up. Tesla arranges for Enterprise of Barstow to pick me up at the supercharger and arranges for a flatbed to tow the car to the Costa Mesa service center, all within a matter of minutes. Within half an hour I'm headed out of Barstow in a monster GMC Yukon, having left my car at the supercharger. 30 minutes after that I get a call from the towing service saying they have my car and are headed to Costa Mesa. All of this paid for by Tesla. Name a stealership in the entire COUNTRY that would have done that for me.
By Saturday night Costa Mesa had it fixed - the service invoice said "replaced battery coolant heater due to low isolation". Apparently the unit failed just like what happened to the OP of this thread, and now I have a new one. Stayed in Vegas until this morning and drove that behemoth Yukon to Costa Mesa, picked up my car in a matter of minutes, and headed south to Carlsbad. Gotta hand it to Tesla's first class customer service - in almost any other make with a catastrophic failure my weekend in Vegas would likely have been ruined and/or I'd still be trying to figure out how get my car fixed and back. Instead I still got my weekend in Vegas and the fix and the rental cost me nothing but about a 25-minute delay to my arrival time in Vegas, AND I already have my beloved Model S back.
This was my first "must supercharge during the trip" trip even though I've had the car for nearly 2 years. I hope my second one lets me get to my destination in the same car I started with. :scared:
apacheguy
S Sig #255
Oct 21, 2012
5,075
1,238
So Cal
Wow, I had no idea that a battery heater failure would bring down the entire car. Sure, I could imagine charging/acceleration/regen limits, but the car should still operate. It's very odd you were able to drive it from full down to 52 miles without any indication of a fault.
GoBlue88
845
251
Carlsbad, CA
According to one of the Tesla guys I talked to, starting to supercharge escalated a minor fault to a major one. A lot of heat coming in from a supercharger.
Kalud
1,056
285
Montreal, QC
Sorry for you misfortune, bad timing!
The charging behavior that you describe before the event is 100% normal. While reaching near 100% the pack starts to do some balancing where is would try to balance each groups of cells to the same voltage. This takes time and its hard to estimate the time needed. The car will always show "Estimating time remaining" often for more than an hour. But you're like 99.9% full anyway so you can leave.
I've observed that graphically multiple time. You can see in the following graph that the State of charge is 100% at the 38 minute mark but it still continues until battery current (not wall current, actual in-car charger's output) drops below 2A at the 86 min mark (1:27)
Here's how it looks like:
GoBlue88
845
251
Carlsbad, CA
They are two different units, a resistive heater and an AC Chiller.
Huh. So then apacheguy has an interesting question: why would a coolant heater failure during supercharging trigger a total shutdown?
Here's the diagnosis from my invoice:
Concern: Customer states: customer states vehicle displayed multiple alerts when charging
at supercharger. Alerts showed Isolation issues
Corrections: Vehicle Alerts General Diagnosis
Reviewed logs and found the HV battery coolant heater to be the source of low isolation
resistance. Coolant heater will be replaced.
Kalud
1,056
285
Montreal, QC
The HV Battery heater is using the high voltage of the battery as power source (400V approx) and for some reason it had an isolation issue (current leakage perhaps or something like that). The battery systems detected the condition and opened the contactor to protect everything, leading to multiple faults (and eventually 12V low battery as its no longer supported by the DCDC converter, from HV source)
apacheguy
S Sig #255
Oct 21, 2012
5,075
1,238
So Cal
Ah, interesting. So hypothetically it could have been a short in the heater electronics causing it to draw all this current which wasn't accounted for. BMS panicks and opens the contactors. Wonder why these heaters have been shorting out.
Reactions: eprosenx
GoBlue88
845
251
Carlsbad, CA
Yeah, would be interesting to know what the rate is for this particular fault. I didn't find many reports of this on a quick TMC search and hadn't heard of it before I experienced it.
GoBlue88
845
251
Carlsbad, CA
2nd attempt at a "must supercharge to reach destination" trip completed successfully. Drove from Carlsbad to Scottsdale and back last week for a golf trip, with Supercharger stops in Yuma, Buckeye, Quartzite, and Indio round trip. No issues, and it was a great drive.
Thormark
35
15
NY, USA
Just had apparent battery heater failure driving about 600 miles round trip upstate NY to PA and back. On the way back, noticed no regen (yellow dashed line) even though I had been driving for an hour. Noticed slow 25KW rate of charge as superchargers. Called support while driving and they are flatbedding car tomorrow. Added hours to my trip (3 SC stops and slow charging at each one). This is a April 2018 model S. Anyone else with battery heater failure?
ODE90D
23
48
Odense
I have my TMS 90D from 12.2015 in for repair after problems with slow SuC. No other issues or error messages but after contacting Tesla support by phone while supercharging super slow (50% below normal) they pulled the logs remotely and could tell me there was a problem with both the battery coolant heater and one of the coolant pumps. Both are defect and to be replaced. Cost is about USD 1.500 - about half is labor. I guess that is acceptable given the fact that I have driven 225.000 km without other issues than a defect door handle.
Reactions: brkaus
Thormark
35
15
NY, USA
Mine was warranty. Just got it back after 2 weeks at service center. They replaced the HV battery pack (no cost of course) and now seems fine. Uncertain what went wrong with a new car/battery pack with only 16K miles on it and they did not give me any specifics.
