YOU, created that problem by checking on the car and waking it.
I am sure you could have a car removed from your account.
It is well known that waking the car causes excess phantom drain.
Edit.
Tesla Account Support'
Scroll down to transfer ownership.
When I googled the page actually came up with the applicable lines highlighted as the first search result.
For an SR+, yes. Not for any long range models. This is a LR RWD.
Whats the VIN? I sold my ~2300 LR RWD back to Tesla back in June 2018 to get a Performance Model and they took a few MONTHS to remove it from my account. Over that time, i could see that they left the car sitting in a lot for weeks on end and eventually the battery died when i could no longer see what it was doing which was pretty surprising.
The car discharges at 1% per day if left unplugged and more if sentry is activated. I would check when the car was taken into their possession.
Do you mean while it is parked and at less than 20%?Once the car drains to 20% it shuts down a lot of functions.
It only disables things when in Park, yes. You lose Sentry Mode, Summon Standby, climate control, and by extension Cabin Overheat Protection. That's really about it.Do you mean while it is parked and at less than 20%?
I'm asking because I recently drove 6,000 miles in two weeks and I repeatedly drained the battery to 4% but nothing shut down. Obviously the acceleration was impacted at a very low SoC, but A/C and infotainment were still working as usual. Nothing seemed to have changed at <20%.
Which "lots of functions" are you referring to? I only know that you can't keep the HVAC system running when you park your car at <20% SoC.
Guy, guys. They just landed the Dragon after a 2 month joyride up to the International Space Station. You don't think the Musketeers put some brain cycles into managing the Tesla vehicle batteries? I wouldn't worry about it. If it's the car you want, at the price you like, get them to deliver a running machine, get a monitoring app, and observe as you charge it up. As long as it wasn't parked in a swimming pool, I'd bet it's just fine.
That waking-by-checking behavior is like the Heisenberg Uncertainty Principle. Can't observe it without affecting it.
Just make sure the car's not forever locked in Valet Mode, as a punitive action against the previous owner
Which is probably why we are seeing so many 12v battery failures. Every 3 days is likely not enough to keep it charged and people aren't driving as much due to the pandemic. I recommend on all the posts about 12v battery failures to use the car for at least an hour every 2 days (Netflix, Spotify, or a game) to keep the car on and charging it.Model 3 has a VERY efficient sleeping pattern. If you dont wake the car it only wakes up every 3 days or so for a couple of hours for battery/12v battery management. when its in deep slumber it consumes 5-6w. The only real consumption occurs when it does eventually have to wake up to recharge the 12V battery which takes around 90min and wastes like 300 watts unfortunately. Sometimes the car does wake up randomly - I think its mainly doing BMS stuff then.
