AlanSubie4Life
Efficiency Obsessed Member
@EV-Tech Exp
I did a couple searches and briefly examined this thread before asking, apologize if I missed the answer:
In regards to maximum discharge rate compared to maximum charge rate for a battery - for the Tesla Model 3 battery chemistry specifically, any idea of what the relationship is? I imagine they correlate (though higher discharge rates are allowed at higher SoC it appears - the inverse of what happens with charging rates), but it looks like discharge is allowed to be faster than charging (or it may be this way only because of the likely duration of the high discharge rate...which would make me wonder about the Model 3 packs that are being tracked at close to maximum power for extended periods...).
It looks like the max discharge rate is somewhere around 350kW right now, from the 75kWh battery, so about 4.7C. Any conclusions on max discharge rate that is possible that we can draw from the 250kW (3.3C) maximum charge rate allowed by the battery?
Just curious about what is the likely output power limit of the Model 3 Performance pack (perhaps the power is limited by the motor and not the pack?).
I would guess that a lot more power might be possible, but Tesla might be opting not to do this because an elevated power output would have to be pulled back quite quickly (not necessarily due to the battery - but due to cooling requirements elsewhere) - which is one of the advantages of the Model 3 over prior models - it tends to do this quite gracefully.
