I am seeing several used Model s's this week with a view to purchase. While I think I understand the battery display, I need some advice.
The display shows the current mileage etc - but only I think in the current state of charge. If I see a vehicle showing - say - 50% battery charge, is there any indication of what the battery might achieve after a full charge?
In other words, how can I be sure that the salesman's assurance that the battery has only degraded to 90% is true?
It's difficult sitting at home with just a manual!
Many thanks
Philip
Here is a method to measure the useable capacity of a Tesla battery. The hard part is that you need to make some observations, then take a trip that consumes a significant portion of the total charge, like 25% at least, then make some observations at the end of the trip.
First, set the display to show battery percent, rather than range. Also, set the right hand part of the small display, in front of the steering wheel, to show the trip computer values. Then, at the start of the trip, make a note of the SOC, the battery percent. Take your trip. Should be at least 50 miles or so. More miles will increase the accuracy of the measurement somewhat. At the end of the trip take note of two things. First, the SOC (battery percent), and kwh used since start of trip. Also, take note of kwh used since the start of the trip. You can also find kwh used since last charge. This is useful if you started your trip just after unplugging. These numbers can also be found in the large display in settings.
Now you do a little bit of arithmetic. A very little bit.
Kwh consumed / (SOC start - SOC end) = total battery capacity
The SOC numbers have to be converted to decimal. So 90% becomes 0.90 and 25% becomes 0.25, for example.
Here is an example: I take a little trip. At the end of the trip, the trip display shows that I used 36 kwh. The battery display started at 80% and ended at 30%. 0.8 minus 0.3 is 0.5. 36 kwh divided by 0.5 is 72 kwh. Note that this passes the common sense test. One half of the battery capacity (80% to 30%) provided 36 kwh. So obviously 100% of the battery would provide twice as much, or 72 kwh.
Critics will state that the SOC measurement may not be linear. I checked. It is very linear. Not perfect. That's why making this measurement after a short trip will give somewhat unreliable values. 25% change of SOC is minimal. 50% should produce a very reliable value.
Note that the advantage of this method is that it doesn't matter how hard or fast you drive. Methods which measure range require you to also factor in your wh/mile. Unnecessary complication.
