Aha, the expert has landed! I have bookmarked the link so I'll always have up-to-date data.Hi. At 12,000 km the average capacity is 97.8% but 97% is perfectly normal. Degradation is faster at the beginning but then slows down. The graph below is from this battery survey. If you enter your data, you can then go to the charts page and select your username and it will show your entry in a different color on the graph. ...@int32_t, when I clicked on your link I saw the old version of this graph that I posted two years ago. At that time, there were too few entries and the trend line was less clear. It was interesting to see how things have changed since then.
Not really sure but I'll double check tomorrow. Unfortunately I did not charge it to 100% on the day I took delivery. I was a bit worried that there could be some faulty batteries since I have only really taken ownership not for too long. But from looking @ the graph it seems like it could happen. Thanks for your help!Are you looking at Rated Range (the EPA-based estimate) or the other estimate (I forget what it's called exactly)?
I don't have a Tesla yet so maybe I'm not the best person to answer, but there is soooo much magic that goes into the range estimate, I wouldn't hang my hat on that 3% number unless you'd done the 100% charge the day you bought it and wrote down what number the magic produced then.
Also, this post might be helpful -- the graph shows that 3% degradation can happen, but then you'd be at the bottom of the bell curve, statistically.
Wow that's very informative. I love it! Great to know that I'm not an outlier. I'll definitely input my data. Seems like your are a pro at this, I have one more question to trouble you with. When I charged to 100% today, the dotted line appeared like in the winter time, is it because the battery is cooling itself? I guess it's safe to assume that it's not good for the battery at all to charge to 100%Hi. At 12,000 km the average capacity is 97.8% but 97% is perfectly normal. Degradation is faster at the beginning but then slows down. The chart below is from this battery survey. If you enter your data, you can then go to the charts page and select your username and it will show your entry in a different color on the chart. This way you can easily see how it compares to the trend line.
If people from the USA or UK enter their data and select their username on the charts page, the chart will switch from km to miles.
Btw, you might want to submit new entries once in a while so you can see how things change over time. A new entry every 8.000-12.000 km (5,000-7,500 mi) is a good idea. Next time you charge to 100%, could you test if changing the range mode setting instantly increases the displayed range like in this video?
@int32_t, when I clicked on your link I saw the old version of this chart that I posted two years ago. At that time, there were too few entries and the trend line was less clear. It was interesting to see how things have changed since then.
Dood! I'm just trying to be helpful. I didn't reply to the exclusion of all others -- we can all offer something, and others did indeed lend their own valuable voices to the conversation. Besides, I have more than a passing interest in lithium batteries and SoC algorithms and have researched the topic extensively (and found that it's best to sum it all up as magic). And my post wasn't altogether unhelpful (if I do say so myself) since I included a link to some "hard facts," to quote Charles Dickens.So why are you answering instead of leaving it to actual Tesla owners who know something about this?
Oh -- speaking of faulty batteries, I believe cell balancing only occurs if left plugged in to something better than 120V (like HPWC or J1772 or whatever) for several hours, with the charge limit set to 100%. Try that if you have access to that kind of power; you might find your range increases slightly. Unbalanced cells aren't faulty, just slightly weaker than the others so that they become slightly undercharged over multiple charge/discharge cycles. Fully charging and then waiting some time gives the battery management circuitry a chance to top up the weaker cells so that they match the stronger ones and get back in balance again, which improves the performance of the entire pack.Not really sure but I'll double check tomorrow. Unfortunately I did not charge it to 100% on the day I took delivery. I was a bit worried that there could be some faulty batteries since I have only really taken ownership not for too long. But from looking @ the graph it seems like it could happen. Thanks for your help!
Thank you. I'll most definitely try it out.You really need to charge to 100 three consecutive days and then measure for any degradation. At this point the stated range is the result of inaccurate algorithms as well and lack of a fully balanced battery. It seems like this is the first time you have done a 100 charge, so the battery is definitely out of balance.
Please try it - I promise your range will increase.
