You must be talking ideal range, not rated range. Not sure idea range was ever speced. P85D EPA rated rage is 253miles at 100%SoC. What is your rated range at 100%SoC today?There is something to this...maybe run it down low also. When mine died, it said 100% was 305 miles on a P85D...about 15 miles higher than I expected. After it died, 100% is now closer to 290 miles. I think the battery lost it's charge reference point sometime before it died.
DId they confirm that they will tow the car each time the car refuses to move with range leftover (up to whatever the range says)?
Btw, if it was me I'd do two things:
- The one curious thing I noticed on your warnings was the 12V battery warning. 12V should never be low if functioning correctly (it gets a constant periodic recharge from the main battery - we have 2 MS which run a dual dashcam from 12V 24/7 and never got a 12V battery warning. Maybe you want to replace it (it is a 3+ year old car)? If 12V is faulty, if could potentially glitch some batter management functions, causing imbalances, or even specifically this issue, the car tries to go, battery management has a brownout and throws a fault. If nothing else, It should eliminate the extra warning when this happens. Cost of a battery is not that big.
- What someone suggested earlier, charge the main battery to 100% a couple of times to let the batteries balance out.
That would make me think there is something wrong with the 12V battery. If the battery was full and drained in 20mins, that would mean the screens are drawing about 100A average current (1200W) since the battery is a 12V/33Ah battery. That is obviously not the case for the Tesla screens, which means the 12V battery has a lot less capacity than expected.1. The 12v battery was complaining because the high voltage battery stopped feeding it. It lasted for 20 minutes until the screens depleted it.
Why replying without fact? What those kind of qualitative statement brings in the discussion honestly? This is an arrogant comment.Winter saps the batterys ability to provide power and driving beyond 65mph further increases the strain. Cold Soaked battery eats energy warming itself. Bad combo. If you've never driven under those conditions you'd never know that the car will use far more than 30kw to maintain speed with the conditions.
So let's put things straight: considering a Model S 75D:
And the Power necessary: P= F total * V = m*a + 0.5*q*V²*SCx + Cr*m*g
- m=2011kg
- q (density air) at 0°C = 1.2922kg/m3
- S.Cx= 2.34*0.24= 0.56m²
- rolling resistance coefficient = 0.015 (Cr at 50km/h) * (1+(0.006*delta V)²) (delta V beyond 50km/h) = 0.1513
So at 105km/h = 29.17m/s and 0°C, the Model S needs 18kW to keep speed constant.
Let's add 2 seat heater (1.5W/km) and HVAC at 23°C (3.5W/km) and you need to add 5W/km.
You can CLEARLY see that the power necessary is nothing crazy in winter compared even to summer and for a car that can deliver 300kW+ in term of power, I don't think 20kW is putting significant strain to the battery.
And NO, the car is not using "FAR more than 30kW" in winter at 0°C at 65mph constant.
You are ignoring the fact the battery uses energy to heat itself
...and ignoring the fact the battery is far more inefficient when cold.
If yours is a software limited 60, then there is a good chance that it is caused by cell imbalance. With a software limit on the top end, there is no possibility for the user to balance by charging to 100%. I would expect that the service center should at least do a full charge/balance during the annual service for software locked cars, but who knows if they actually do. I also would expect that they would have observed the imbalance when you brought the car in and report that as the cause and but instead they say nothing is wrong. Something is wrong somewhere. It could be possible that if the battery was charged some before it got to the service center that could mask an imbalance but I would expect it to still be logged.I bet some well-known owners will get "Tesla's special treatment"!
FYI, Tesla will be returning my car tomorrow without a fix. They said they couldn't find anything wrong, but it could be a software glitch. (I heard the same excuse two years ago!)
I'm definitely unhappy. I hate the fact that I cannot trust my car anymore.
There was a post here some time back about someone who needed to get towed to the Supercharger from, essentially, the off-ramp, and how his rated range had not shown there was going to be an issue. Apparently the Supercharger was uphill for the last little ways, and the driver had been speeding quite a bit.
More to the point, though, why would you want to constantly run your battery down to 1KM? You know that's not good for the battery, right?
Lesson? Don’t drive EV’s close to the red line unless you feel lucky.
That might have been me.
Before this experience, I often increased my speed when I was confident that the range was sufficient. I was thinking: why not have some fun close to the supercharger; refill will be fast.
On that day I was going maybe 180 (km/h, not miles). But it was also a lot of uphill. The battery was down to about 6 % of its range when the car shut down.
Roadside assistance was great. They explained to me that the battery was under stress (probably heatwise) so that it wasn't charging the 12V battery any more - for some time. I still had the first 12V battery and about 240,000 km on the odometer. So it might have been a bit weak anyway. I replaced it the next chance I had.
Moral of the story: Do not aim at arriving with less than 10 % range. If you do, then chill, slow down. If I had known what I know now, this would not have happened.
It appears that these cases are infrequent, if not rare, based on this thread. So it’s quite possible Tesla has indeed adjusted to a more conservative estimate. Clearly many people have gone below 15% (me included) without shutdown.Shouldn't Tesla adjust their range estimators more conservative then?
What good is a low end of a range estimator where you can't go under 15% (or whatever number could be deducted from the experiences in this thread)?
This nonnegative bias is always a pleasure to experience.![]()
Seems you did not read the comment you were responding to. 180kmh it's no problem for the Tesla.As for 180 kph, well we all know Teslas are crappy autobahn cars.The California dragstrip cars that they are...
