Battery Drain While Sitting in Garage
Discussion in 'Model S: Battery & Charging' started by cplaw, Sep 23, 2016.
  1. cplaw
    cplaw Member
    Los Angeles
    I noticed that my battery drains about a mile a day while just sitting in the garage with no movement. Is that normal? I do you Visible Tesla. Is that the source of the drain? If so, if I delete the program from my computer, would the drain stop?
  2. SDRick
    SDRick Member
    SD CA United States
    One mile per day is on the low side. I think most are seeing at least 2-3 miles per day, some up to 10?
  3. Dakkor
    Dakkor Member
    Lachenaie, Quebec, Canada
    It's called Vampire Drain and it is normal. The car is always on, So there is always some juice getting drained.
  4. cplaw
    cplaw Member
    Los Angeles
    Thanks.
  5. auger
    auger Member
    SoFL
    I have a P85+. With all of the energy saving features on, I lose 3 miles/day.
    I used to lose 1-2 miles/day. I don't know why it is much higher now . . .
  6. rpo
    rpo Member
    Washington
    My S85 loses 10-12 miles in the first 24 hours sitting in the garage at ~70 degrees. After that it drops about 4 miles/day. It's ridiculous. There have been weeks where I drive only 30 miles but the car uses even more energy just sitting there.
  7. Pando
    Pando Member
    Sandy Ego
    Like a leaking gas tank. In a few years there will be 500,000 cars in garages wasting away energy. Hopefully there will be a way to shut off Model 3 completely, I wouldn't mind a longer reboot.
  8. whitecotton
    whitecotton Member
    Houston, Texas
    I had a firmware issue causing excess drain on my car( that was a side effect). It took a while but it was traced down and fixed.
