I am having a problem with supercharging that I am hoping some of you might be able to enlighten me on.
I have a new long range model S. First super charge seemed fine. Cold day. Peak charge rate was 143 kW. But next super charge on a much warmer day was a problem. Peak rate was close to 140, but then it quickly decayed to about 60 kW. This happened a second time, and then I noticed I did not hear any fan noise. So I took it in for a service check, and they claimed that everything checked out OK and that the fan was working, although it was “very quiet”.
Well, on a hot night here three nights ago I tried again. Now it peaked at 117, and again quickly decayed to 60. No fan. But wait! Then I noticed charge rate was climbing, and I heard fan noise! Rate climbed back to 80 and then slowly decayed as I would have expected for the charge level of the battery.
Questions:
1- has anybody experienced fan start delay?
2- the fan is very quiet, compared to my prior Model S. Is this normal for long-range Model S. Or might it be too slow?
3- is the charge-rate decay caused by battery management control sensing overheat, or just battery physics when battery is hot?
4- has battery potentially been damaged?
5- What did I forget to mention or ask? See graphs below of last charging session from “Stats” app.
Earliest available service appointment is set for 10 days from now...
Questions:
