Utter hogwash. This is exactly what I am talking about. Broad statements like this make a potential buyer go. What?
It it true.
This statement is supported by very many research reports.
This is my now sold M3P after 66K km.
I had about 17-20% supercharging and about 35 full charges, still way better than the average of the same car.
The dip in the middle was the BMS loosing track of the capacity. I did a 100-0% drive at the lowest dip which proved 79kWh capacity.
There are many many more cars in the teslafi data, but the setting for this pict only covered 5 other.
Changing to all 400 cars did not change the average line.
So, my last two full charge was 490km and 492km, out of 507 km
The average cars
How can this be? Charging to 100% results in less degradation than charging to 80%.
There is more than one calendar aging test that show the highest calendar aging happens around 80%. The reason is also given in a few of them, above 80% the self discharge in the cells are quite high, but from 80% and below the self discharge is low. I havent digged into the exact chemical details (I have tried to stay outside that box, and focused mainly on what happens, not why) but what they say is that the self discharge stream of current reduces the calendar aging.
More or less all research show signs of that the calendar aging can be higher at 80% than at 100%. At elevated temperatures (40C and more) the worst calendar aging often is at 100%.
While It could be good to know that 100% not always is worse than 80% the takeaway is that high SOC, thats above the ”step” cused by the central graphite peak (google that or look for my posts here about that) cause about the same degradation.
Also, that 100% is not at all as bad as the forum myths say, in most cases 100% is about the same as 80-90% in terms of calendar aging.
Theres often no need to leave the battery with 100% for a longer time, like overnight or so…but if needed by asny reason the battery will not take damage from it.
