Newbie here who hasn't taken delivery yet (soon) trying to learn as much as possibly before the car arrives. The battery pack has to be heated when the weather is cold and cooled when it is hot. Cooling is handled by a compressor which cools glycol circulated through the battery pack, the motors(?) and the inverters(?). That same compressor presumably cools the cabin by, presumably, sending that same glycol through a liquid to air heat exchanger. Is that correct?
The real question regards heating. Is that done by using a separate resistance heater or by running the compressor as a heat pump which sucks heat out of the air and transfers it to the glycol? Seems to me that in moderate climates at least that would result in more BTU per kWh than straight electric heat (and thus less impact on range) as the COP can never be less than 1. Anyone know the answer to this?
