Battery is big disappointment
Discussion in 'Model 3: Battery & Charging' started by azred, Jul 28, 2017.
Tags:
  1. alseTrick
    alseTrick Active Member
    Florida, USA
    That wouldn't seem to make any financial sense for Tesla.
  2. jelloslug
    jelloslug Active Member
    Greenville, SC
    The voltage is not the same between the different sizes.
  3. jgillispie
    jgillispie Member
    Illinois
    I thought it would be 5-7.5 but I also thought it was going to be a 60-75kwh.
  4. alseTrick
    Florida, USA
    But driving 75mph+ with the AC on?
  5. dhanson865
    dhanson865 Active Member
    Knoxville, Tennessee
    Not just doubtful, totally disproved by the two vehicle weights given.
    • Curb weight:
      • 3549 lbs. (Model 3)
      • 3814 lbs. (Model 3 Long Range)
    • Weight distribution:
      • 47% front, 53% rear (Model 3)
      • 48% front, 52% rear (Model 3 Long Range)
    • Like x 4
    • Informative x 2
  6. Trancela
    Trancela Member
    Canada
    This may be an issue with the 215 mi T3. There may not be enough cells to generate the power needed for a 4 sec 0-60. And then the motor needs also to be bigger and the power connection fatter. It is more than just the inverter.
  7. electracity
    electracity Active Member
    Yes, that was more my point. Decent highway travel range doing whatever makes you happy. The point behind buying the S/X 90 and 100.
  8. Trancela
    Trancela Member
    Canada
    The gap between 215 and 310 is just about right. I am more than happy with 215, while others need a 310. The range points are about right.
  9. macpacheco
    macpacheco Member
    Brazil
    Try to drive your gasoline car at 75mph and see what mpg it gets vs the advertised mileage.
    Driving at 75mph will hurt range, EV, Hybrid or fossil car.
    75mph isn't normal speed.
    But the faster you go, the less significant AC off/on will be in your total range.
    I think you will get the advertised range at 55mph with AC on or 60mph with AC off. Something like that. 75mph will get 25-30% less range.
    Increasing your speed by 50% about halves your mpg. Same thing for gasoline cars.
    Expect anything else at your own peril. Its pure physics. Car makers wont (ever) use 75mph to calculate range.
    • Disagree x 1
  10. Trancela
    Trancela Member
    Canada
    Or being the lighter car, the 215 car is 50 kWh -- which is the perfect capacity for a 2nd car.
  11. schonelucht
    schonelucht Well-Known Member
    Nederland
    No absolute battery sizes given??!?
  12. electracity
    Yes, it is too slow.
    • Like x 5
    • Informative x 2
    • Disagree x 2
    • Funny x 2
  13. Trancela
    Trancela Member
    Canada
    Not really. If the T3 has 4000 cells (for a capacity of 50 kWh), then it can generate only 100 kW, which is not a lot. The Leaf is at 80 kW, and the i3 at 120 kW. Tesla may run the cells at a higher discharge rate (at the risk of cell damage) and you may get up to 150 kW and not more. 150 kW is not enough to allow 4 sec. 0-60.
  14. alseTrick
    Florida, USA
    I'd be pretty stoked to drive 75mph with AC on and get 250 miles on a mostly full (90%?) charge. It might be good enough for me to upgrade to the larger battery, actually.
  15. jelloslug
    Greenville, SC
    AC usage is negligible to the battery consumption.
  16. alseTrick
    Florida, USA
    I see your location is Brazil. Idk how familiar you are or are not with US Interstate driving. But 75mph is absolutely normal. And driving 55-60mph for efficiency-sake will take you forever to do any long-distance traveling in the US (I know Brazil is a decent sized country, too). Not to mention, the lower the Tesla's state or charge, the quicker it will recharge, so better to drive fast and run the battery down, no?
  17. ItsNotAboutTheMoney
    ItsNotAboutTheMoney Well-Known Member
    Maine
    It's the modular nature of batteries. The minimum range was probably determined by module size.
  18. gjunky
    gjunky Trifecta: Solar and both cars are EVs
    Scottsdale, AZ
  19. ItsNotAboutTheMoney
    Maine
    Uh 75mph isn't normal for me, since I stick to speed limits and I live in 70mph country, but I can assure you that 75mph is very normal in lots of places.
  20. ItsNotAboutTheMoney
    Maine
    I'd have liked something in between, but it really wouldn't be possible without complicating battery production.
