I can't believe that we've had our classic MS70D for 5 months now and almost reached 7,000 miles in our tenure!
It appears to have a battery in very good condition and even after 7K miles (37K in total) it still charges up to an indicated 200 miles (Typical) at 90% which equates to 222 at 100% - roughly 2.2% degradation from what I have gathered from reports of range when brand new of 226-227 miles.
Our longest single non-stop drive was 186 miles from home to Darts Farm (Exeter) on the way to Falmouth. Teslafi reckoned we used 80% battery or 51.26kWh. Arithmetically, that's 100% = 64kWh.
On that trip we managed an average of 5% better than the car's predicted energy efficiency/range for the destination.
I've only seen one suggested real capacity for a new classic 70D battery and that was 68.8kWh - which suggests degradation is actually much worse. But I have no idea how Teslafi works things out.
Anyway, I digress. Battery Management.
I understand that periodically the BMS needs to be recalibrated. I've read that this should involve running the car down to significantly below 10% and then charging back up to 100% and the keep plugged in while the cells are levelled.
So I have a few questions:
1. Is that how to recalibrate?
2. How often should it be done?
3. Do you need to use a Supercharger or is home charging OK?
4. Does this make a difference to the reported Typical miles (up or down)?
Over to you!
Over to you!
