Battery not charging properly
Discussion in 'Model 3' started by YusufT, Sep 3, 2018.
  1. YusufT
    YusufT Member
    Vaughan, Ontario
    So before my Model 3 charged to what ever limit I set it to. I dropped the car off at a paint shop to get delivery issues fixed, and they had it for a week and a half. Since the day I picked up my car my battery has been acting up with charging.
    Before when I set the limit to 90% for example, it would charge to 449/450km which is correct. Now, once it’s finished charging on the notification it would say the correct battery charge but when I get in the car it would be much lower like 430. This happens for any limit I set the car to and I’ve been charging daily for the past week I’ve had the car. I don’t know what’s going on.
  2. sreams
    sreams Member
    Sacramento, CA
    It tends to be difficult to set the limit to exactly 90% using the car's screen or the app. It doesn't seem to easily "snap" to those percentages. You might try doing a 100% charge once and see what happens (preferably just before a longer drive).
  3. dano9258
    dano9258 Member
    Las Vegas, NV
    How long between the end of charging and getting in your car? You might have vampire drainage.
  4. YusufT
    YusufT Member
    Vaughan, Ontario
    Like 3 hours after it’s done charging so I doubt it’s vampire. And I’m setting it to correct percentages
  5. AltLogic
    AltLogic Member
    SoCal
    I would do a reset then open and close all doors and trunks to make sure they are fully closed. Also check if cabin overheat protection is on.
  6. ebmcs03
    ebmcs03 Active Member
    So Cal
    During one of the recent updated Tesla did change the calculations a little. I remember reading about it. It’s been my experience too. It use to charge to 279 or something like that and now it charges to 274 at the same % setting I have set.
  7. SageBrush
    SageBrush 2018: Drain the Sewer
    Colorado
    Are you setting the limit by the phone app or in the car ?
    Is there a difference ?
  8. YusufT
    YusufT Member
    Vaughan, Ontario
    Yeah it’s the exact same settings as before I dropped the car off except for the software version. It’s also cooler now than it was almost 2 weeks ago.
    Yeah that’s what’s happening to me. What gives? I think it may be the update. 90% before update was 450km, now it’s 435km. But the app gives me a notificiation once charging is complete and it says 450km on it only for me to enter the cat 2-3 hours later and it saud 435.
    Setting it through the car
  9. ebmcs03
    So Cal
  10. YusufT
    YusufT Member
    Vaughan, Ontario
    Thanks for the thread. So it’s almost guranteed to be a software issue? So only select few is having this problem? This is so odd.
  11. ebmcs03
    So Cal
    I’m not sure. Maybe others are not so sensitive. Or OCD as us few that notice a few mile difference.
