Battery pack balancing techniques
Discussion in 'Technical' started by rabar10, Aug 11, 2014.
Tags:
  1. rabar10
    rabar10 Model 3 >> Focus Electric
    Indianapolis, IN
    Found a great paper that covers lots of techniques for balancing series-connected cells in a battery-pack.
    IREE - A Review of Passive and Active Battery Balancing based on MATLAB/Simulink
    It covers technical highlights of several different methods of cell balancing, then compares them on time-to-balance, complexity, size, and cost. Granting the fact that I'm a nerd, I thought it was both good and informative. One thing that is not covered is a failure-mode analysis, i.e. effects from one part of the balancing circuitry failing.
    Does make me curious what specific flavor of balancing is in use in the Tesla pack/BMS.
  2. kennybobby
    kennybobby Member
    Heart o' Dixie
    #2 kennybobby, Sep 16, 2014
    According to this paper it would be switched-resistance passive balancing. Their premise is that balancing is required due to an assumption that cells can become unbalanced--this is based upon one citation from a battery conference in 1997 and a self-reference to one of their own papers.
    But how can a parallel string of 74 cells (a 200+ Amp-Hr modular CELL) become unbalanced? They can't, the voltage across each cell is equal.
    The Tesla BMB/BMS is primarily a monitoring device (volt meter) to provide real-time voltage of the 96 modules in the 85kWh pack. The 0.1 Amp switched resistance balancing circuit could be used to make very slight adjustments at the end-of-charging current, or could make bulk pack adjustments over ~30 hours if a single cell were to fail open or blow a fuse.
    The more important device in my mind is all the electronics on the large current shunt resistor that measures pack current. There is no current monitoring circuitry on the BMBs.
  3. rabar10
    Indianapolis, IN
    #3 rabar10, Sep 16, 2014
    Yep, the BMB switched passive bleed-resistor balancing method is used in the Model S pack, as discussed here: Pics/Info: Inside the battery pack
    At first, I was surprised that they didn't use an active balancing method, to take energy from the highest-capacity group of paralleled cells and pump it into (or supplement the energy being provided by) the lowest-capacity group. But I think one of the critical factors that was not discussed/analyzed in this IREE paper is failure-mode analysis. The failure-modes tend to be much worse with the active charge balancing systems (specifically the potential for higher-voltage faults) than it is with the passive balancing system.
    RE: the electronics on the large current-shunt -- guessing that includes a very robust analog filter/gain stage (filter design is very important here, as covered in that other thread), A/D conversion, and then isolation between the pack (voltage at the point of measurement) and the 12-volt LV system. The current for each paralleled cell group is the same as the current through that shunt since they are all connected in series (with the possible addition, per cell group, of current passed through the individual balancing bleed resistors if/when they are switched on).
  4. EldestOyster
    EldestOyster Member
    Moonlight Beach
    If the quality control is good (the cells are matched), they will go out of balance very slowly. A bit of controlled shunting is all that's necessary to keep them drifting out of balance over a long period of time. The gains to be had from rerouting currents is going to be quite small. I expect the amount of power in question would be pretty small compared to any that would be used to heat or cool the cells. Simplicity wins here, without much tradeoff.
  5. Soolim
    Soolim Member
    Vancouver, BC, Canada
    Based on switched resistor charge balancing of the battery pack, some questions come to mind:
    1. What is the threshold that triggers balancing?
    2. What is the rate of the discharge on the cell?
    3. How long does it take to achieve balance? Is it done in one cycle or completed in multiple cycles?
  6. manikanta raju
    manikanta raju New Member
    India
    This is a value you set in the battery Main control unit firmware. A good guess would be when any of cells deviate more than 5% from the average state of charge. When i say cells I mean the whole parallel block of 18650 cells.
    This something which is dependent on the chemistry and the cells safe operating region. An 18650 cell generally has a safe nominal discharge rate of 0.5C. Given the cell capacity is ~3Ah. You could discharge each cell at 1.5A nominal. considering 74 parallel cells, you could discharge 74*1.5 = 37A.
    The time taken again depends on the balance current and the ability to bleed charge. More imbalance more time. More balance current lesser balance time. It is done in multiple cycles. Its like this, the BMS balances the cells a bit, checks for deviated cells. balances again checks again. This process goes on till all cells are under allowed state of charge deviation.
  7. emir-t
    emir-t Member
    Istanbul
    Thanks for the info. I have one question though. Shouldn't BMS look into every cell instead of a parallel group? Because those 74 cells within a parallel group can also have an imbalance, or a cell might die blowing the fuse. Wouldn't not checking each and every cell in that 74p group be risky? I don't quite understand why every parallel group is always in balance.
    One of the issues causing imbalances is manufacturing capacity variance. In a parallel group those variances are still there. One cell could have 3280mAh capacity while another has 3340mAh and so fort. Or is your group as strong as the weakest cell? So if a cell loses capacity all the way down to 2800mAh, would that make the whole group go 2,8 * 74 = 207Ah capacity? I'm guessing no beacuse if that were the case a cell's failure would cause a whole group to die, instead of just losing ~3Ah capacity.
  8. DougIngraham
    DougIngraham Member
    Rapid City, SD
    You can't look into every cell in the paralleled group unless you provide a way to disconnect every cell from the paralleled group. This would add a lot of cost and a rather large increase in failure modes with no advantages. Fortunately you don't need to. If a cell shorts and blows the fuse then you will quickly see that paralleled cell groups loss of capacity. There are 74 cells paralleled and ~ 3.2AH per cell for a total of 237 AH. 100*(3.2/237) = 1.4% loss of capacity. The BMS will pretty easily see this cell group is out of balance with the others and prevent you from over discharging. A reduction in range of 1.4% will be the end result. You would probably see a revised range estimate once you did a 100% charge including the long balance that would take place followed by running down to the bottom. For me this would be going from the 263 indicated full charge miles down to 261 miles. A single blown cell fuse might just be passed off as normal loss of range due to ageing. But the car would know.
    Sanity check time. 237 AH * 3.7 volts nominal * 6 series cell in a module * 16 modules = 84.182 kWh. That is pretty close to 85 kWh and could be either the 3.7 volts being a tiny bit low or the 237 AH being a tiny bit low. Sanity check complete. The 90 kWh packs are probably closer to 3.4 AH per cell. The 100's have re-engineered modules and may have more cells in parallel. I've not seen a breakdown but Elon did say that the same cells are used so I would assume more cells of the 3.4 AH capacity in parallel. This would be going from 74 to 83 cells in parallel. But I am now off topic.
    Doug Ingraham
    2013 Model S 85 Multi-coat Red "The Woman in the Red Dress"
